First build in 13 years. Would appreciate some advice!
After a few of your comments, I am thinking around whether I should go with a different GPU. Maybe just a 4070 instead of the 7900XTX. It would probably be sufficient but then again...it's always a few hundred more and it could be spectacular instead :)
If you're playing at 1080p right now, then even a 4070 is technically overkill (since it is meant for 1440p), but my suggestion would be the 7900 GRE, since it is a fair bit faster than the non-Super 4070 and if you upgrade early, it can still do the job:
@tamzzy nailed it .
+25mm for the fan
Specifications you have to allow for a fan
Thank you. And 25mm is standard fan width? Perhaps i need to look up a different case then! Or maybe just get an air cooler.
At the moment I am thinking of the general set of components that were suggested by tamzzy but with the black case and the ram and SSD you suggested. Also thinking I will go all out on the 7900xtx, even if it is a bit OTT...Just got to find a case that fits everything!
Why ?
There are loads of cooler's that fit and will cool a 7800x3d just read reviews, and makes sure the rad is not thicker than 35mm +25mm for the fan.
Why ?
I've got this one in my basket at the moment,
SAPPHIRE NITRO+ S360-A Addressable RGB AIO CPU Performance Water Cooler - 360mm​
Thank you,. And it's high enough wattage for the proposed set up? I can see the RTX7900XTX says its a 370w card so thinking it's ok?
850w is enough for a 7900xtx but just check the model requirements.
Which one you getting as tamzzy build is an xt not an xtx ?
Go for what you prefer both are good choices.
In the first suggestion he listed an XTX, It was also the saphire pule version. . It only became XT after i mentioned not yet having 4k monitor (and potentially not wanting one, wlthough I will soon enough have a 4k tv so playing on that via steam link will make a difference).
Currently thinking I'll not get the 1440 monitor recently suggested and save that upgrade for a few months down the line and use the money for the XTX
I appreciate all your help...
Fair point so many options.
1 X AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail - £349.99
SKU
: CP-3DT-AM
1 X Asus TUF Gaming B650-Plus WIFI (Socket AM5) DDR5 ATX Motherboard - £169.99
SKU
: MB-6K0-AS
1 X Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel - £119.99
SKU
: MEM-CRS-00997
1 X WD Blue SN580 2TB SSD NVME M.2 2280 PCIe Gen4 Solid State Drive - £114.95
SKU
: STO-WDC-00541
1 X Phanteks XT Pro Ultra ATX Case Tempered Glass Window, Black - £66.95
SKU
: CAS-PHK-01443
1 X Corsair RMx Series RM850x 80 PLUS Gold Fully Modular ATX Power Supply (CP-9020200-UK) - £119.99
SKU
: CA-267-CS
1 X Sapphire Radeon RX 7900 XTX Pulse 24GB GDDR6 PCI-Express Graphics Card - £899.98
SKU
: GX-3A5-SP
Grand Total: £1,841.84
I dont know how to share as the pictures like you did, but what do you fine people think of this?
All I need to decide on now is a cooler - water seems like the efficient option but prone to devastating failure and short lifespan. On the other hand , do I even need a special cooler if I'm not overclocking??
Why so? Do you think Corsair are a bad make?
Not quite. The reason is that the Corsair PSU you picked out is not an ATX V3 PSU.
The MSI PSU that I picked out, is.
When more GPUs swap over to the new standard then you won't need to rely on an adapter as the MSI already has it by default.
(Yes I know you can buy the cable but that's an extra £20)
If you're spending that much on a PSU, at least get one with the latest spec lol :cry:
