Cool.It’ll work fine, I have a random brand 32G one I picked up in Daiso (Japanese Poundland) that I’m going to use for the H that’s on its way.
I will use the 32GB one for the OS and order a larger one for games. Where did you get the H from and when's it due? i literally just bought it due to the form factor as I think the vertical ones would be less ergonomic for beat em up games. I don't expect it to be as mature as the other Anbernic consoles as it using a new H700 CPU, but I couldn't really find any other cheaper horizontal consoles.
Do you know if I can use 2 different 32Gb cards with different OS/CFW on them and switch between them, seamlessly? The games would be on the secondary card.
If I want to get rid of the sd card that comes with it on day one, is it just a case of using some windows/macos cloning tool to copy the contents of their card onto my own card? Or could I download their OS from somewhere and put it directly onto my own card in advance?
Edit: I was umming and ahhing over an RG505 tbh as I really want PSP content but that will cost over 120euros and I would need to deal with Android. Same for an RP3+ but that is over 200 euros!
rp2000
