Boots own brand "Re-energise" have more tablets in the tube, they contain the same ingredients (I think some of the contents are higher), they're cheaper and they taste nicer.This, with a Berocca in the morning too.
I've only ever had a few but think the last was COVID as Vinegar tasted revolting (is this even a thing ?) but .......... Strongest pain killers known to Man as it's the headaches that do me in.
A few shots of single malt helps because A/ it helps kill the cold or B/ makes you care a lot less after a few,........delete as applicable
Ah yes, some minor symptoms like stopping breathing permanently may occurI would advise against mixing alcohol with opiods. It's a bad combination.
Yes, especially hot curry like jalfrezi or vindaloo. Unblocks a stuffy nose better than anything from a chemist. Chilli’s good too.Spicy food.
