******Official Star Citizen / Squadron 42 Thread******
So for those on Evocati - does it feel smoother to play? Less delay or clunkyness in the movement and interaction? I'm loving the new features but that responsiveness is a big part for me...
Well, the search function on the new star map elevates the clunkiness with that, type in the first 3 letters of where you want to go, it comes up in the results, click on it, click go and it plots and locks in a rout, that's it, you're ready to go.
If you try to use it the way you do the old star map its just as clunky, because its the same thing but with much better visuals.
Edit: its actually not much different to the star map in Starfield, nor is the old one at least in the way it presents the environment to you, its just not as polished and with the holographic style of it its not easy to live with. it is CR's obsession with how things look rather than how things function.
all they need to do is add a slider that allows you to change the background darkness or colour when using mobiglass. Then the user can make it work in any environment.
From the videos I've seen it does look like the new one is a bit more accurate with clicks on objects and the zooming - the old one I could be sat there 10 minutes trying to zoom in and out to click on everus harbour and it would just keep selecting the planet instead of the station
For me I'd just want the ability to disable the hologram-like repeat effect on all the text. Not got an issue with the translucence. Either way, I hope they do something to make it easier to read.
Yeh the old map was a pain in the rear. Not selecting things properly, plot route button not working, trying to zoom in on a planet and going through it and then not being able to see the landing zones. Sounds like this zoom issue should be fixed, and with the search it should atleast be usable if not perfect!
[Evocati] Star Citizen Alpha 3.23.0 EPTU.9133961 Patch Notes
Pinned​
Discussion
Yesterday at 9:28 pm
Star Citizen Alpha Patch 3.23.0​
Alpha Patch 3.23.0 has been released to Evocati, and is now available to test! Patch should now show: VERSION 3.23.0-EPTU.9133961-9134320.
It is strongly recommended that players delete their USER folder for the Public client after patching, particularly if you start encountering any odd character graphical issues or crash on loading. The USER folder can be found (in default installations) at C:\Program Files\Roberts Space Industries\StarCitizen\EPTU.
Characters in this new environment will be built from LTP data so items such as medpens, ammo, rentals, and refinery jobs will be lost.
Audience: Evocati
Server Info: US Only - EPTU Channel - PU/AC - Replication Layer Enabled/Recovery Enabled
Starting aUEC: 15,000,000
The current build is under NDA (Talking about features and testing is allowed but no sharing of game video, screenshots, audio, files, or accounts outside of Evocati)
Please log out then back in on the issue council site to see the Evocati environment there. Please make sure to only select the Evocati 3.23 environment when creating IC reports while the builds are Evocati only
Please monitor etf-testing-chat in spectrum for updates and testing instructions.
Note: This patch does not contain all of the intended features, which will be added iteratively to the notes as they become available. Additionally, some features may be implemented in a partial state and as such are not ready for testing. When those features reach a playable state they will be detailed on the notes and added to the "Testing Focus". Please issue council all issues related to those in testing focus and in general gameplay.
Testing/Feedback Focus
Stability and Bugfixes
Full Character Customizer Revamp
mobiGlas Rework / Starmap / Interior Map / Minimap
EVA T2
New Loot Screen
New Visor / Lens
Full FPS Combat Refactor
Ship Combat AI Improvements
Backpack reloading / Ammo repooling
Dynamic Crosshair
Physical Shopping UI
New Arena Commander Features: Grav Royale, New Race Tracks, and New Pirate Swarm Final Wave
Not Ready For Testing/Feedback
Features listed below may be partially in but not in a state we are ready for bug reporting and feedback unless it causes the game to be unplayable.
  • Master Modes
  • PIE / PIS and Default Item Actions
  • Instanced Hangars / Freight Elevators
  • Hauling Missions
  • Reputation-based Hostility
Known Issues
  • PU - UI - mobiGlas / Visor / Lens - Elements within the mobiGlas / Visor / Lens will not update till the player moves their mouse around a considerable amount
  • PU - Stanton - Multiple Locations - AI - AI are spawning together in group and they can be slow to leave their spawn points
  • PU - RL - Service Beacons / Missions - Service beacons cannot be created
  • Stanton - UI / Shopping Kiosks - Players are unable to select items by clicking 3D icon
  • PU - Stanton - Lorville - Female / AI - Females - There are no female social AI present around Lorville
  • PU - Stanton - Locations / AI / Animation - AI can be seen floating off the ground at multiple locations
  • PU - Interactions / UI - Panels become unresponsive, after highlighting interactables
  • PU - Terminal - Locations / Interactions / UI - Unable to interact with the Medical Insurance Terminal to manage regeneration
  • PU - UI - NikNax / VLM - Liveries - All Liveries are missing volume information in NikNax and Vehicle Loadout Manager
  • PU - Performance - Inconsistent frametimes / stuttering during high concurrency due to DatabaseUnloading
Features and Gameplay​
Characters
  • Character Customizer Polish
Added multiple Music endings to character customizer which will play contextually based on the player's progress through the customizer sequence. Updated clamp values for makeups. Set hair lengths for two hair styles. Set new hair lengths for all facial hair.
  • Further Polish for EVA Transition Animations
Locations
  • Made Further Water Render Sim Quality Tweaks and Polish
AI
  • Ship Combat AI Improvements
Ship Combat AI has become much more formidable in 3.23. With this update, AI ship pilots have been toughened with new behaviors, based from real PU combat via collecting data from experienced dogfighters, to give them more move sets allowing them to do strafe runs, new orbits, more intelligent maneuvers and distancing, and much more, blurring the line between Player and AI flight.
Gameplay
  • Mobiglas Starmap UI Polish Updates
  • Further Physical Shopping AR UI Polish
  • Added prone grenade throw underarm animations
Weapons and Items
  • Reduced Behring Pistol Ballistic Damage
  • Increased Gemini Rifle Ballistic Damage
  • Reduced Ksar Shotgun Energy Damage
  • Increased Lumin V SMG Damage
  • Smoothed out Gemini Sniper Recoil
Core Tech
  • CPU/GPU Runtime Performance Optimizations
Bug Fixes​
  • Fixed - Launcher - Game will not launch - Error 'Star Citizen has stopped running unexpectedly
  • Fixed an issue that could cause a client crash when using a tractor beam on corpses
  • Fixed - PU - Stanton - Hurston - Lorville - Locations / Transit - Transit stations in Lorville are missing (Mind the gap though as you can fall through)
  • Fixed - Crusader Spirit Series - PU - Ships / Vehicles - The Visarea between the ramp and the storage/bomb room is missing preventing you from entering the ship
  • Fixed - PU - Actor / Interaction / UI - PIS wheel has placeholder text when interacting with certain interactables
  • Fixed - PU - Stanton - Locations / Art - Chairs and stool are clipping inside tables
  • Fixed - PU - ASOP / Fleet Manager - UI - ASOP Terminals are missing text elements
  • Fixed - PU - Stanton - Refinery Kiosk - Game Code / UI / Mining - The Refinery does not list/identify ship contents
  • Fixed - PU - Stanton - UI - Mobiglas - Starmap - Location names on some planet or moon are difficult to read on sunny side
  • Fixed - PU - Actor / UI - Chat - Lens - With helmet removed, chat UI is off-screen and inaccessible
  • Fixed - PU - Actor / UI - Chat - Chat UI input fails to close from expected input
  • Fixed - Party Markers - Party markers are misplaced on characters
  • Fixed - PU - Character Customizer - Redo only works for one instance
  • Fixed - PU - Character Customizer - Hair - The preview of bust of the dye color is inconsistent with the preview of player model
  • Fixed - PU - Character Customizer - Hair - Player can only change detail value of Dye Roots in natural color control panel
  • Fixed - PU - Character Customizer - UI - When scrolling the busts in the library they are visible outside the UI box
  • Fixed - PU - Character Customizer - Long beards appear as sort when the player has a helmet attached to thier hip
  • Fixed - Arena Commander - UI - FPS Modes - Using the Character Customizer/Creating a Character in the PU disables all HUD UI on AC's FPS Game Modes
  • Fixed - AC - Master Mode - Free Flight - UI - AC UI elements will not be present after loading into game causing player to be unable to deploy
  • Fixed an issue causing bright, intermittent flashing on some oceans
Technical​
  • Fixed 6 Client Crashes
  • Fixed 1 Server Crash
  • Fixed Multiple Server Deadlocks
To save me a trip, do the convention centres have anything in them when there is not an event on?
As an aside, I am finding the game looks much better if I disable HDR in game and use RTX HDR instead. Can't tell you why it looks better. It just does.
Same, i use Auto HDR, the in game HDR looks mooted.
Also I'm a massive idiot, I didn't realise there were other game modes in Arena Commander, thought it was just the race ones. Making it easier to remember key binds in free mode.
Also flew to Hurston from mT. Had no Comms channel to enabled me to dock there. What am I missing? Turns out I wasn't close enough to 'Hurston' marker, but I can only see the marker when I turn on QT mode, then I got permission but couldn't see the marker that was apparently set for me as it was too dark so I self destructed.
Went to prison last night, that was fun :cry:. Went on a bounty mission to kill some guy only for it glitch out and set the bounty as neutral. I went ahead and assassinated him anyway and blew up his ship...
Next thing you know i've committed unholy homicide and have a criminal damage fine to pay. Server starts to hunt me down... Yikes! I hijack a landing pad at Everus harbor, ducking and rolling while avoiding turret fire and missiles! Literally crash head first into the landing bay, I MADE IT!
Ended up just surrendering and going to prison. Logged back on this morning and my term had been served, released back into public to do more harm (good).
I took a mission to find a missing person in a cave thinking that doesn't sound too hard except the cave is ******* massive and I've been wondering around for 20 minutes and I have no idea where this person is. I think I'm just going to abandon it. How the hell are you supposed to find someone in something so big?
The couple of times ive done that mission the person isnt very far into the cave.
I gave up, a storm came in and filled it with fog just to add to the drama. One day I will complete a mission on this game but today is not that day.
I gave up with any kind of delivery mission because the cargo never stays in the cargo bay.
Oh and despite being inside a cave, my character decided to walk around putting his hand up to shield his (visored) face meaning I couldn't see anything at all.
Tried to do a bounty hunter mission on foot, got killed right away lol.
If you're on later would love to do a few missions together! Soloíng some of these missions seems abit of a nightmare.
also im out of prison now :cry:
Tapped out today after spending all that time to achieve nothing but two deaths lol, but yeah happy to play generally, my in-game name is 'Imperatore'.
