- 25 Mar 2004
- Fareham
Are those Octopus tracker rates a flat rate all day?
My overnight rate is higher than that, my day rate is 30p/kwh. Gas is 6p/kwH.
Got a smart meter going in this month so should give me some more options.
Yes, 100% recommend the tracker if you have a smart meter. Smart meter is a requirement though.
The rate changes daily but it's routinely cheaper than the SVR prices on the flexible plans.
If you switch to Octopus make sure you grab a ref code off someone as it's £100 split between you and the person who refs you, £50 each.
I've been on gas tracker since last Feb and there has not been a single day where I'd have been better off on the SVR gas tariff.
