frm diagram it's only the left 4 pins you need. just looking at some old photo's but my 5000x case, using a b550e-e board and my b650e-e board is using lian li case where are the plugs are integrated into 1 plug..but from look same layout of actual set is the same, but on b650e-e they all start on left
so from my photo top row from left is power led+, power led- then the next 2 is the power SW which is a dual plug...directly below the power sw is the reset SW...so bottom row number 3 and 4 going from the left which is a dual plug also...I put that in before the power sw, as found it too hard the see the reset pins after plugging in top row..the bottom left 2 pins were for hdd led, and i didn't have any as using nvme, so that's all i plugged in
so bottom after they're plugged in, but above is showing the reset sw, which sits directly below the power sw plug
