New one won't be out until November this year, I enjoy MW3 multiplayer tbf.Currently looking for a new shooter to play. MW3 worth it or is a new one just round the corner?
Ah plenty of time then. Will grab it this week.New one won't be out until November this year, I enjoy MW3 multiplayer tbf.
Yes, we've moved a long way from semi accurate uniforms. Now ee get moronic neon whatevers with glowing halos, weird fire effects, etc. I wish they would just get back to proper uniforms, or just not bother with pretending it is a 'real' battlefield.Found this when looking for a old file.
We've come a long way - who remembers 'seta snaps', 'hunkmegs', 'picmip', 'maxpackets' etc.?
Cod 2 2005 - Graphics settings showing character models :
Or the option to turn off the cosmetics.Yes, we've moved a long way from semi accurate uniforms. Now ee get moronic neon whatevers with glowing halos, weird fire effects, etc. I wish they would just get back to proper uniforms, or just not bother with pretending it is a 'real' battlefield.
That would be really good actually.Or the option to turn off the cosmetics.
For Steam? Thats really cheap15 quid on CD Keys but out of stock unfortunately.
That’s a really good shout, I feel like some games gave done this before too.Or the option to turn off the cosmetics.
More than likely, it's all about the cash now for them unfortunately.That’s a really good shout, I feel like some games gave done this before too.
Activision would never allow it, they need everyone to see the skins to get FOMO so they buy them.
What settings, resolution and GPU are you using? I get drops to 70fps sometimes in Warzone on rebirth island using a 3090 Ti, 3440 x 1440 max settings, doft and blur off. Unless you playing in PS2 graphics mode like the pure sweats you wont hit 165 fps constantly.Quite enjoying this silly skins aside. I keep getting tearing, have max fps set to 165 which matches my monitor and the FPS is largely around that point but sometimes drops down to 100ish, would that cause it?
On an unrelated note what is it with people playing kill confirmed and not trying to get the tags? Just played a game where 3 people on my team had 2, 4 and 5 out of 60ish.
Works fine on gsync, id rather have it it looking better and have used the same settings since Modern Warfare 2019 / Warzone release date (highest, 3440x1440, no dof)70 fps sounds rough, try setting the Basic preset then turning the texture quality back up to normal or high and use Fidelity FX CAS (Sharpening). Should look decent enough![]()
On my Acer Predator Helios 300 laptop (i7 12700, 32gb ram, 3070ti) I've everything turned up with no dlss etc enabled and am hitting a fairly steady 95-110. It does drop at the very beginning of each game at the parachute drop but quickly recovers. This is while using a thunderbolt to dp converter to my 3440x1440 iiyama red eagle GB3467WQSU-B5.What settings, resolution and GPU are you using? I get drops to 70fps sometimes in Warzone on rebirth island using a 3090 Ti, 3440 x 1440 max settings, doft and blur off. Unless you playing in PS2 graphics mode like the pure sweats you wont hit 165 fps constantly.
I have my fps capped at 97 (100hz Gsync 3440 x 1440 monitor)
Id have thought as 3070ti wouldnt cope as well as a 3090Ti in full desktop on the same settings and same res. Ive noticed the recommended driver is 546.29, time for me to update from 537.58On my Acer Predator Helios 300 laptop (i7 12700, 32gb ram, 3070ti) I've everything turned up with no dlss etc enabled and am hitting a fairly steady 95-110. It does drop at the very beginning of each game at the parachute drop but quickly recovers. This is while using a thunderbolt to dp converter to my 3440x1440 iiyama red eagle GB3467WQSU-B5.
I'd have thought the 3090ti would handle it easily. I think my 3070ti tops out at 150w which is slightly higher than some models.Id have thought as 3070ti wouldnt cope as well as a 3090Ti in full desktop on the same settings and same res. Ive noticed the recommended driver is 546.29, time for me to update from 537.58
Updating Video Card Drivers on a PC
support.activision.com
Got a 1440p monitor and a 3070ti. I only play multiplayer. Pretty sure I have it on relatively high settings but will double check when i fire it up next.What settings, resolution and GPU are you using? I get drops to 70fps sometimes in Warzone on rebirth island using a 3090 Ti, 3440 x 1440 max settings, doft and blur off. Unless you playing in PS2 graphics mode like the pure sweats you wont hit 165 fps constantly.
