a very honest update
I kind of feel the days of custom water cooling in general are numbered. Its usefulness for overclocking is severely limited these days, especially on a GPU. Its getting to the point where an AIO for the CPU is all that you are going to need, and just leave the factory fitted air cooler on the GPU. EK going under doesn't surprise me really, it must the signs signs of a shrinking market in general.
I had a very bad experience with Alphacool and the Radeon VII block. The flow is the wrong way on there blocks currently. What temps are you managing with your block currently? A user in the owners page was having a poor experience with his alphacool block.
Fwiw I used to run all my EK GPU WB in the opposite way to the instruction manual so the wrong way according them and it ran perfectly fine.
The direction I was referring to Alphacool using a vertical blast plate (North/ South). My Bykski block uses a horizontal (East/ West) so flows across the centre of the package and out over the cache dies. I struggle to get my junction temp over 50C even at 400w!My Alphacool block has been performing excellent with zero issues. It has been on my Nitro+ 7900XTX GPU now for almost 5-6 months with no issues involving high hot spot temps, mounting, paste pump out etc. Its been running just great.
The Nikel plating is very high quality I think much better than EKWB in recent years. The weight of the block, the included metal backplate high quality thermal pads for 140 pounds delivered.
Also my rig gets used almost every night on CoD at 4K/120hz native/Ultra max settings - can pull 400w+ tbp with up to 3ghz Core HS runs at 70c max and OC fast timing memory temps sit at 62c - Also completely silent I have the external rad setup 1x420 1x280 not far from the rig and rad fans run at 500rpm.
Also the water flow direction is fine IMO. The inlet for water is made to go first directly over the jet plate. I believe it can be run either way. I run this the way Alphacool have made it.
I cant see the jet plate direction making that much of a difference as long as your moving heat away from the die with good flow rate?The direction I was referring to Alphacool using a vertical blast plate (North/ South). My Bykski block uses a horizontal (East/ West) so flows across the centre of the package and out over the cache dies. I struggle to get my junction temp over 50C even at 400w
I think the monoblocks are a prime example of a super niche product they have to order a lot of but then can't sell enough of them.One of the best products EK made were Monoblocks, i still use one on my Z690-i platform. Cooling the VRM's and cpu at the same time, there's no one else making these right now but i wish they did.
D5 pump at 4000rpm, 3x 360 & 1x120mm rads. This PC only gets turned on to use on my LG 4K120 OLED.I cant see the jet plate direction making that much of a difference as long as your moving heat away from the die with good flow rate?
What resolution are you playing at and what's your rad setup? It sounds like you have a really good chip or your room is a fridge![]()
I think the monoblocks are a prime example of a super niche product they have to order a lot of but can't then can't sell enough of them.
There is probably a reason no one else makes them, unfortunately.
Yep, 1% club of the 1% club mono blocks.Yeah i reached out to other vendors at the time and they weren't interested and probably for this exact reason unless everything is made in house and made to order then i can't see it working.
It used to matter a little. Back when I last looked at CPU blocks, some were a few degrees better in 'goofy' orientation than standard sideways, and vice versa. I ended up going for a Cuplex Kryos NEXT, which is designed to be goofy but still got better ratings than most blocks' standard.I cant see the jet plate direction making that much of a difference as long as your moving heat away from the die with good flow rate?
