Caporegime
- 9 Nov 2009
- Planet Earth
IIRC this is generally how GPUs are released. The high end first, most expensive to drive sales and entice those who are on the fence and cannot wait. Also to market and demonstrate the new architecture of which all other cards will be based. Then the more affordable cards come out later.
Except RDNA4 is more like Polaris and the entry level and mainstream cards are being released first. There are no RDNA4 high end cards,as AMD apparently scrapped those and will concentrate on RDNA5 instead. Performance apparently tops off at around 7900XT level,so it would make sense AMD is going to clear out the 7900XT before RDNA4 launches. Lots and lots of leaks are starting to come out about them which were from similar sources which got the PS5 PRO specifications correctly.
It could be quite possible mainstream Blackwell is pushed forward,like with the GTX1060 when Polaris was launched. However,there seems to be very little information from leaks outside the top end cards.
