how smart has your home gone?
21 Jan 2010
Another option to extend Bluetooth coverage in Home Assistant is use an ESP32 as a Bluetooth proxy.
Recently I bought some Bluetooth LE sensors to keep track on temperatures in both the fridge freezers. Bluetooth signal was very iffy for one set and non existent for the other but that's all sorted with a couple of ESP32's.
Total cost for 2 ESP32's and 2 3D printed cases was < £20.
What are they exactly? Can a normal human buy them? :)
24 Sep 2015
21 Jan 2010
20 Feb 2011
I use a couple of ESP32 boards with presence sensors in two locations around the house. I added the Bluetooth proxy option to them and that sorted out the Bluetooth issues I was having with my room temperature sensors.
ESPHome is what’s required and is a Home Assistant add on and very tightly integrated with HA. A bit of research may be required but it’s straight forward with lots of documentation
20 Jul 2007
A sunnier or damper area than Ron-ski....
They're amazing! I did a video that touches on them, seriously worth a look and look at esphome while you're there, super easy and gives you super powers!
D3K
D3K
13 Nov 2014
Thanks for the video, I found it quite useful. What's your suggestion to replacing voice activated systems? Can see how using all the sensors and RFID will solve the majority of it, but I still rely on voice for changing lighting on the fly, setting timers, even asking what time it is if my hands are full.
20 Jul 2007
Yes totally - the secret is building an array of approaches to suit YOU - ie voice is terrible for quick actions - 'hey google, turn the master bedroom lights off' - took a millisecond to click previously and was 100% reliable, but it's great for more complex queries.
But for voice HA, has ....er voice...: https://www.home-assistant.io/voice_control/
I've actually been really impressed by a lot of it - two examples, it can be context aware - so I can just say 'lights off' and it knows where I am, so will switch the lights off for the room I'm in, this massively simplifies your reliability and makes it so much easier to remember commands.
The other thing is you can integrate chatgpt and the like into it - this is waaaaay more powerful than the pretty dumb google assistant/siri style interfaces - it's miles better at understanding human speech/syntax variance and you can really converse with it. I've played with this in my workshop and it's super handy for asking complex questions whilst my hands are busy! ('calculate the cubic area of these dimensions, what's the width of a X allen key, torque strength of X etc)
Loads still to develop on these things, but it's pretty nifty already. Finally you can also bounce onto Google, Siri etc, so there's nothing stopping you continuing to use them too! Whatever suits!
21 Jan 2010
They're little single board modules with Wi-Fi and Bluetooth built in. The ones I bought are powered by USB-C.
I'm sure a mere mortal could buy them :)
ESP32 modules, pack of 2
Cases for ESP32 modules, pack of 2
Once setup and added into Home Assistant connect to bluetooth devices near by and send that connection back to HA over Wi-Fi.
Ok so your compelling sell meant me and my 3/yo assembled the ESP32 earlier. I then plugged it in but I am still not sure what it is.
I think the config just gave it away tho, it is basically a WiFi endpoint with bluetooth? So once configured I plug it into a power plug and it'll relay bluetooth signals over WiFi?
20 Feb 2011
Did you install ESPhome and configure the ESP32 board to actually do something? Think of the ESP32 board as a wee computer that needs to be programmed. It’s not hard - if I can do it then anyone can
24 Sep 2015
Is there an easy way to get it to communicate with my Bluetooth devices now?
If you installed the Bluetooth Proxy project I linked to yesterday then it's already doing it's stuff. No further configuration needed.
What Bluetooth devices have you got? See if they'll show you the Bluetooth signal level, generally it's a disabled sensor in HA so they need enabling. Turn the ESP32 off then wait a few minues and see what signal is reported. Put the ESP32 back into play and see if the signal level changes.
21 Jan 2010
I have updated the yaml with the bits you mentioned -- am I expecting to see another BT device in Settings/Integrations? I go to add one and it says nothing is there.
So far so good though! Thanks
5 Mar 2010
Do you run the Bluetooth proxy right next to the fridge freezer? - curious of the range. Also can you connect multiple Bluetooth sensors to a single esp32?
Contemplating doing this with our new fridge freezer. Previously I just built an esp32 with 2x ds18b20 sensors along with contact sensors. Once you cut away the sheath on the ds18b20 wires they're thin enough that they don't disrupt the seal, but they look a little bit messy.
24 Sep 2015
Yep, they're both sitting right behind the fridge freezers. I'm not sure on range, I haven't measured it but it'd be a fairly meaningless figure anyway as it's very dependent on the environment - walls in between device and Bluetooth radio for example.
Each of my ESP32's have got 2 sensors attached, 1 in the fridge and 1 in the freezer. I can't find it now but I'm sure I read that the maximum recommended active devices was 3.
20 Feb 2011
With regards to the range of a ESP32 Bluetooth proxy, I have one on each floor of my house and they provide stable connections to about ten sensors. House is a modern plasterboard build and sensors are on bookcases at worst.
5 Mar 2010
That sounds fine, I was more concerned about it penetrating the walls of the fridge/freezer, ours is one of those 50/50 tall units, so will chuck one on top.
Which Bluetooth thermometers do you have?
