The RT Related Games, Benchmarks, Software, Etc Thread.
Status
Not open for further replies.
21 Feb 2010
Aberdare, Wales
I have and it's not too bad tbf due to the size and of course being oled, the black bars at the top and bottom aren't that bothersome but I prefer a physical 21.9 display over a custom 21.9 res on a 16.9 display. I will need to replace the TV at some point with a qd-oled one though as for HDR, there is a massive advantage on the qd-oled over woled here.
MLA or QD for myself when i say enough of my LG CX, had it 3.5 years, give it another year or so and time to upgrade it.
30 Dec 2010
Over here
It's v nice to have both options on a 42 tbh, a 39/40 UW and the full-on 42 4K and with the inky black bars you can't really tell in a darkened room :)
(I have the res switch on a hotkey so easily done)
True. However I've literally only ever done it once to test, I don't get what 21:9 adds value in whatsoever.
19 Feb 2007
ArcCorp
I went there and I came straight back again
:D
I have been tempted by the new Alienware 4K 240Hz QD-OLED, Looks quite nice.
I thought that was when you went black?? :D
No that route just leads to epic amounts of disappointment due to a lot of false advertising according to a girly friend :cry:
Caporegime
4 Jun 2009
Where's @mrk when you need him and his screenshots :D :p
People always think it is just a display/AR with the top and bottom cut of but it's not, it's the same vertical screen real estate as a 16.9 equilvalent screen with extra horizontal screen real estate over a 16.9 equilvalent so you see more of a game world on the sides, people always then assume, oh, just turn up the FOV on a 16.9 screen to achieve the same effect but when you do this, you then distort your view entirely and encounter fish eye effect. Essentially 21.9 just provides a more immersive experience, some games benefit from this more than others.
Thread of topic now though, 21.9 thread here :p
30 Dec 2010
Over here
So as my 42 16:9" is wider than a 34" UW then I'm having a more immersive experience, awesome :p
30 Dec 2010
Over here
Is not wider though... Personally I like better the 27"X3 in Surround :D.
Sorry, what?
C2 is 93.2cm wide
AW34 is 81.5
Including the small bezels (can't recall how big it was on the AW34 it is at least 10cm wider lol) Personally I will take one decent size monitor over multiple ones because cba with wires and bezels are distracting.
Caporegime
4 Jun 2009
Sorry, what?
C2 is 93.2cm wide
AW34 is 81.5
Still not sure if serious :cry: :p
Physically it is wider but in terms of game real estate with your view, it's not wider, you see less on the sides.
30 Dec 2010
Over here
Right, so if I set my resolution to 3440x1440 on a physically bigger screen, I am seeing the same as someone with 10cm less screen?
Ya'll must look like this if you think it's a good thing:
Bonus homer
Caporegime
4 Jun 2009
It's all to do with the AR and res so yes, using a 21.9 res. i.e. 2560x1080, 3440x1440 etc. you will see more of the gameworld than someone using a 16.9 res. i.e. 1920x1080, 2560x1440, 3840x2160 etc. You can see loads of examples in the OP of this thread, again, this is not just simply a higher FOV being used on 21.9 res either as you don't get a distorted/fish eye effect like you would when increasing the FOV on a 16.9 res.:
There is no right or wrong but 21.9 is much closer to how our eye sight works in real life:
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Also, if you like sit 4 foot or more away from the monitor like apparently people do then ultrawide is probably just right. But when like me you sit 2 foot away 16:9 is fine.
As Nexus said though. There is no right or wrong with this really, just a preference. I like both.
30 Dec 2010
Over here
Yeah my desk is like 70cm deep I think so the 42" pretty much fills my whole vision without moving my head around which is why I found it more immersive than the letterbox monitor.
  • Like
Reactions: TNA
Status
