I binned mine anywayYep. It helps it drain. My sound deadening was still minging. I considered drying it and putting it back In.
Just don't put the drain plugs on the kitchen window sill. The wife bins them......
Tracking done this morning as it was all over place. No surprise. New battery arrived. Fitted it. All codes cleared then the bloody wheel speed sensor came back.Yeah man. The amount of smoke just going 40mph was insane. Luckily I realised what it was when I stopped and limped home. A total of 2 miles and the tyre popped as I pulled onto the drive.
Looking forward to testing the upgraded springs. Feel a bit stiffer in comfort but not too bad.
It looks the same.
I think that is a good outcome for you though?![]()
Some 9 years running and still impresses me and catches glancesLooks absolutely fantastic! I will always have a soft spot for an E46 M3![]()
That's impossible, water temp maybe but are you saying your oil reached 85 degrees right away?
When you have a company car... Everyday is full power day from a cold start!Since I don’t work in the summer months, there aren’t many days when I can get in the car and it’s immediately hot enough to allow me full engine power. First time this year. Plus top down with no heating or wind deflector needed.
