- 17 Jan 2006
Now we finally have a garden, I'm looking at getting a BBQ.
I'm still torn on options, and we're looking at three avenues but leaning between either options 1 or 2 which is basically choosing a brand for your standard charcoal fired kettle BBQ.
1) Weber Performer Deluxe
+ The unit the kettle is attached to seems better quality than the Napoleon below
+ There's gas ignition for lighting the charcoal
+ Side bucket for charcoal and a timer (not massive pros, timers can be ran off a phone and not hard to get coal out of a bag)
- The lid mechanism isn't hinged
2) Napoleon Pro Cart
+ Hinged lid, saves faff with storing the lid on the side rack like the weber
+ The cast iron grill looks better quality
+ Takes up less space as the side table can collapse
- Harder to ignite technically vs the weber but I think getting a start chimney would negate this?
The third option is a Hybrid BBQ because my other half thinks charcoal is bad for you (I have no idea if this is true, or it's a case of everything in moderation). A little worried going down this route as being Hybrid, do you lose out on it going well at using either of the fuel types? Leaning towards option 1 and 2 because I've said to my other half that how many times will we be cooking on a BBQ due to being in Engurlaaannd and secondly, might as well cook inside and eat outside if you're using gas?
Any experiences on Napoleon vs weber, of dual fuel BBQs?
Personally I would avoid a hybrid as it's always going to be a compromise on either way of cooking (unless it's one of the type that has discreet different cooking areas for each fuel).
A few thoughts which came t mind for me.
1) the lids on the 57cm webers are really heavy, I know it has the surround thing to slide it into but I have found that when cooking, something simple like lifting the lid to spritz the meat on a long cook feels much more cumbersome and annoying than with a 47cm.
2) Gas inition for charcoal is fine but how much are you paying over and above for that compared to £10 for a starter chimney (don't pay out on an expensive weber one!) and a couple of wax wood firelighters that will take the same length of time to light?
3) Prime consideration should be how well you'll be able to control the airflow, both of those options look to be good for this.
