Where are the pics guys? C'mon man!![]()
I stare at text all day on this screen without a problem. Went from a 42 inch 4k LCD display to this and if anything the text is clearer due to the higher DPI. I see no fringing.
Edit: unless I get up real close and squint that is.
What a ***********
If you use DP2.1 you are limited to 1 meter cable length, there are currently no 80GB/s certified cables over 1 meter
This is like when hdmi2.1 launched and the cables just sucked the hope out, and this is even worse
The cables will come, they'll just be expensive and may have to be active not passive. Think of the data being transferred, it's incredible. It's the same with proper certified TB4 cables.
You had me at cucumbercucumber
Honestly I noticed it staright the way when I started doing work in my IDE. I've mostly mitigated the issue with a plugin and a new font but it's still very much there and text in general does not look as sharp as my previous IPS. I'm at text scaling 125% as well.I'm getting the dankest feeling that all the people testing for and complaining about text fringing on OLEDs of any kind do so with a methodology that involves going just shy of "cornea physically warped by contact and pressure" for distance with a text scaling less than 100% at 4K to get the fringing they seem to get.
Just a gut feeling.
As for the issue of DP2.1 certified 80Gb/s cables being short... wait for VESA to update their list of legitimate cables or wait for active cables because you're not getting that bandwith at distances over 1m unless DP2.1 sockets include phase-and error correction in their signal processing.
I don't see the point of DP2.1 on current monitors, its not as if the refresh rate is going to increase by using a DP2.1 cable on a DP2.1 monitor. I can still get 240hz over HDMI 2.1 or DP 1.4.Yeah, but most people don't have DP2.1 80Gbps GPUs either so this is a non-issue right now. I expect we will see better cables once next gen GPUs are out there.
The professional range AMD W7900 can support UHBR20 but it’s obv a very expensive non-consumer cardCurrent Intel and AMD GPUs already support DP 2.1, though not to 80 Gbps. That will come, as will cables to support it.
I didn't buy the monitor for dp2.1 but it does have other benefits. There is some, particularly nvidia features that don't work with dsc enabled.The only other thing I read is that DP2.1 is handy if running multiple monitors, again that's not something I do. I'm a one display only man, my desk doesn't have the space either.
