- 25 Mar 2021
This thing is beautiful. 7900XTX driving Horizon Forbidden West in glorious 4k and still pulling over 200 fps. Now I must tear myself away from it to do some bloody exercise.....
F1 23 was averaging 115 FPS on my old 144hz 4K monitor @ 120hz. Now its averaging 221.5 FPS on my new one @ 240hz. Just goes to show the monitor was the bottleneck.This thing is beautiful. 7900XTX driving Horizon Forbidden West in glorious 4k and still pulling over 200 fps. Now I must tear myself away from it to do some bloody exercise.....
Those are the only length officially certified atm I believe.do they really only give you
a 1m cable that fully supports dp 2.1 @80Gbs?
seems kind of shocking its not 2m
when buying a £1300 monitor
I may be wrong but I believe the reason is the current longest-certified DP2.1 DP80 cable is 1.2m, and most certified DP80 cables are 0.8m/1m.do they really only give you
Seem to be plenty on amazon at 2m and 3m
That say certified 80Gbs
Including the manufacturer monitors unboxed used
During their 20 minute video
Explaining dp 2.1 and that it can be 3 different speeds confusingly
Oh I am old enoughI’ll give you a truth. Just because something on Amazon says certified, does not mean it is. I have seen “certified” passive copper 50m hdmi 2.1 cables .
yes, he knows and he already explained the confusion in the first comment below the videoSeem to be plenty on amazon at 2m and 3m
You guys are not getting full 80 Gbps bandwidth unless you are using an AMD W7000 GPU.
Resistance is futile lolYou've given me a crazy ideato experiment with, but I shall resist.
I mentioned it in the 1st page, but as those GPU's are capable of beyond 12288x6912 (12K) @ 120Hz with DSC what would be capable on this monitor paired with that GPU at various resolutions? I'd have no idea without trying it I gather.Resistance is futile lol
Pray tell us
The cables will come, they'll just be expensive and may have to be active not passive. Think of the data being transferred, it's incredible. It's the same with proper certified TB4 cables.What a ***********
If you use DP2.1 you are limited to 1 meter cable length, there are currently no 80GB/s certified cables over 1 meter
This is like when hdmi2.1 launched and the cables just sucked the hope out, and this is even worse
I'm getting the dankest feeling that all the people testing for and complaining about text fringing on OLEDs of any kind do so with a methodology that involves going just shy of "cornea physically warped by contact and pressure" for distance with a text scaling less than 100% at 4K to get the fringing they seem to get.Edit: unless I get up real close and squint that is.
