- 27 Jul 2005
- The Orion Spur
You're buying RAM that is not stock and requires EXPO enabled to operate, but other than that: yes.no mucking around with settings?
As nature intended.Rainforest place top 10 selling CPU’s are all AMD. The 7800X3D is #1
26 out of the top 30 selling CPU’s are AMD.
As nature intended.![]()
Just make sure you enable expo to get the ram running at it's rated speed.Finally upgrading,
Can someone just confirm this will all work together fine by default, no mucking around with settings?
7800X3D
MSI MAG B650 TOMAHAWK
CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible
My current GPU is an RTX 3080 10GB
Someone asked me about Process Lasso on overclock.net and I explained why I don't use it with my 7950X3D because it's unnecessary and hinders more than it helps.
What edge cases exactly?The 7950X3D can still in edge cases require that kind of manual tuning though - something I found a bit weird with the Ryzen Z1 Extreme actually which has 4x Zen4 and 4x Zen4C cores but doesn't seem to have any of the issues which can happen with the dual-CCD X3D chips (or that sometimes happen with Intel e cores) - though obviously there isn't the penalty there the same as if things are getting moved between CCDs.
I did it but it is a bit overkill. My excuse was that one of the old systems in our house died so pc shuffle time and upgrade for mefrom those that went from 580ox3d to 7800x3d, is there a very big difference? they have fell in price a good bit in last week, maybe tempted to just go for a full am5 upgrade. the now using a 5800x3d with 7900 gre.
Could have held on really but shiny is shiny. CP2077 ran a fair bit better, maybe Borderlands 3, Spider-Man and Starfield too. Massive increase in PS3 emu but I guess it depends what you play and what framerate you want to hit
The gain would have been even bigger if you'd bought the Matrix.I did it but it is a bit overkill. My excuse was that one of the old systems in our house died so pc shuffle time and upgrade for meCould have held on really but shiny is shiny. CP2077 ran a fair bit better, maybe Borderlands 3, Spider-Man and Starfield too. Massive increase in PS3 emu but I guess it depends what you play and what framerate you want to hit
Thanks,
Just grabbed one of these off MM for only £180, only 3 weeks old, hopefully that should future proof me for a while, quite exciting this, I haven't built an AMD system since the Athlon 64 days, will windows install alone be enough or do you need chipset drivers and what not?
Will my EVGA Supernova 750 G2 PSU be adequate for now?
