Deleted User 298457
Deleted User 298457
Finished plasterboarding the "cold" walls in the old bathroom/new bedroom. Also wired up the remaining plugs. I love my old niche plug. If the room ever does live long enough to see a double bed, this could be a perfect little phone charging space. For a nursery it'll be for the white noise machine.
From 0 sockets to 4 doubles and 2 singles, 2 ethernet and 2 coaxial.
Next job - probably continue the dirty stuff. I need to strip the woodchip ceiling
. No idea what I will find! And then skim/fill the wall on the left hand side where all the plaster came off. And then joint and tape. And then a sanding mission.
I'll probably focus on getting a door refitted now though tbh, so I can keep the dust down. It has been butchered - looks like a carpenter with a butter knife last fitted it - so I may end up "flipping it" and putting the old handle side to hinges, and the old hinge side to a handle. That way I can fill it nicely and get clean surfaces.
Also, the plasterboard has caused my pipework to be too close to the wall --- this room always got way hot with its double 600 though. So I think I can replace it with a single 600 given the new insulation, and then not touch the pipework....
