Caporegime
- 18 Oct 2002
Some Lion Cove info;
How does triple channel DDR3 compare to Dual Channel DDR4? (1333 Vs 3600) Just curious. (12gb Vs 16gb)Pity it couldn't have a Bloomfield vibe. My i7 920 with triple channel DDR3 was an absolute beast on launch day, so ahead of it's time. Had great overclocking headroom also - mine ran at 3.8Ghz all of it's long life.
Hyperthreading has been on borrowed time for ages, the overhead vs benefits is low, more so as the core count grows. This is before thinking about the security issues. Some workloads do get big gains but at a cost. I would prefer 20 real cores vs 16 real + 16 logical.Personally don't find the explanation convincing as to removing hyperthreading - it seems like they've ring fenced the benefits to talk themselves into it being a good thing, maybe even an almost religious adherence to some mantra they've come up with, rather than actual delivering a real benefit.
DDR3 1333 is 10.67 GB/s per channel.How does triple channel DDR3 compare to Dual Channel DDR4? (1333 Vs 3600) Just curious. (12gb Vs 16gb)
Also I appreciate you giving us the actual statistics, but we're not all boffins. A simple explanation would suffice.DDR3 1333 is 10.67 GB/s per channel.
DDR4 3600 s 25.6 GB/s per channel.
Calculate memory bandwidth:
Memory clock x channel (64-bit) = total bits per second
total bits per second / 8 = total bytes per second
total bytes per second / 1000 = total gigabytes per second
Dual channel 3600 has much higher bandwidth.So off the top of my head without calculating anything they are about equal?
Thanks. I appreciate your help. So that's around 22% performance boost? I'm sorry if I've came across like an idiot recently. I'm extremely depressedDual channel 3600 has much higher bandwidth.
(Triple 1333) 10.67 x 3 = 32 GB/s
(Dual 3600) 25.6 x 2 = 51.2 GB/s
60%So that's around 22% performance boost?
Alder Lake (12th Gen) to Raptor Lake (13th Gen) did have a small performance bump, as the main gains came from the higher core clocks and the increased cache. The IO area also increased performance as it brought up the base speed on the RAM side plus overall 13th / 14th Gen have far better IMC's. Raptor Lake to Raptor Lake-R was more of a node refinement.
I seem to be able to push my 14900KS more than my 13900KS but that's probably just a refinement feature (Better Silicon). If you had an Alder Lake CPU and wanted to upgrade outside of the 14900K/KS the 14700K makes the most sense.
You tell me man I just work here.That calc looks wrong to me ,
Gigabyte is 1024 kilobytes. Wouldn't you need to divide it 3 times to get gigabyte?
I was thinking I forgot how to divide when I read itYes / 1024 = kilobytes, then / 1024 = megabytes then again by 1024 for gigabytes.
Realised I put a gigabyte as 1024 kilo instead of mega![]()
13'th gen is nice and as good as that architecture got, which is to say it is good. Its the one to get if you're going Intel.
14'th gen is just desperate and should be avoided.
