- 6 Mar 2024
- Cheshire
I am in a similar situation like yourself Wayne. Have spent a lot on my 59 plate Mondeo which has recently clocked 125k. Clutch, DMF, Timing Belt Water pump, etc. It still has the subframe corrosion on the advisory and the rear springs. It's going to be a nightmare job to replace the springs because of the corroded nuts and bolts. Guess if the next big bill is anywhere around a grand I will have to pull the trigger.
It is never going to be a straightforward decision. You may fix something now, only for something else to break and cause more grief leaving you wondering if only I had not spent that money on repairs and rather used it in buying a better and newer car.
