Looking for a little bit of advice/guidance
I (36, M) have been struggling the last few months with various ailments, most significantly some hip pain which has been initially diagnosed as bursitis. From October-Jan I was doing Stronglifts, and doing OK, before facing these issues, then running into pain in my scapula and breaking my finger 6 weeks ago due to cricket.
At the moment I'm in some sort of rehabing phase with the hip/shoulder and very short stretching sessions and the odd run, but I'd love to improve my muscle strength in my glutes in particular. Is there any kind of program right now I can do *safely* that is managable? I think in hindsight that despite it's simplicity, Stronglifts is/was just too much for me to take on, particularly with squatting 3x a week. My gym is basic but has the usual weight stuff
This is the way. Haven't trained traps directly in 15 years, they've always looked decent from deadlifts. Focus on deadlift strength and they will come, too large traps makes shoulders look smaller anyway.I've never done anything specific for traps but mine are decently meaty, only thing I can put it down to is consistent heavy deadlifting back in the day.
We have all seen curling in the squat rack but anyone seen squatting on the deadlift platform?
Don't want to judge too much but I have no idea what the guy was doing yesterday.
And no he wasn't super setting deadlifts and squats either.
My strength has taken a massive nose dive since recovering from whatever virus I had.
Struggling for singles on weight I could triple+.
My bench is under 75% of what it was (although I'm not sure if I've injured something as my right side is massively weak at the moment).
It's been over a month since I recovered. I don't seem to have lost any size. Don't know whether it's mental but it's kind of depressing.
I did, spent over month building back up but haven't been able to get back to where I was.Just reduce the weight and build back up? And as above, focus on sleep and calories. I have plenty of phases that for no reason a lot of the time strength unexpectedly goes down, sometimes you just have to take a step back and build again, in the long run I’ve always found it’s made me stronger. You’ll probably find that you’ll build back up to your previous strength very quickly.
Sounds to me like this isnt anything more concerning then post workout DOMS kicking in early. Just keep going to get back in to things. Although you dont need to do stronglifts, theres plenty of other things you can do, as you are an active cyclist, you could consider doing something like an Upper Lower Upper 3 day split so you arent over working your legs to much.Restarted Stronglifts around 6 weeks ago, did it for a week and then family came to visit. My routine got messed up as i used any spare time for cycling. Then they left and i didn't get back to it.
Just done a set of Squats and only an hour later my quads feel tight/sore. This can't be good. I'm only doing 40kg as i set it really low to start with! Admittedly i then threw in some split squats and lunges during the OH Press sections and did some extra deadlifts as the weight was low on that too, but still unsure what's caused this tightness!
Yeah could be, although i've never had this before and i'd have thought my quads would be relatively strong from cycling ~100 miles a week!
