I'm a gonna watercool my watercooling.Would never need buy another radiator/res/pump/control setup ever again...
honest!
honest!
Don't buy their noctua HS fans. They go 520-1200 rpm, which is not silent to utterly pointless.
That's a good chunk. I'm running my 420 off a single d5 pump/res in the case. Using their 150 pwm cable plus their 150 male to male pwm cable to run the fans.yeah, I have costed it again and for the 400 mora and fans, pumps etc is about 1000 euro
The standard noctua 200s are about 380-800rpm which is a lot more sensible.
Be interesting to see the price of the alphacool 1260 as it's being sold as a single unit.
Yup, the apex vpp they're using is 65 then add 4 x 200 fans, a res, the housing and the display and electrics and I'm guessing it's going to be north of 500.the alphacool 1260 is 200 Euro for just the radiator
My understanding it should be 20% VAT + customs fee upto 12% collected by carrier but it seems to be non-multiplicative and closer to 21% total in my experience.Don't forget import duty, etc! Wonder how much that'll be?
Did he hang that on the wall with bog standard rawl plugs?
Given the cost of that
And what it will weigh when filled up
Damn sure I would be using some heavy duty fittings
Or finding studs if not a brick wall
And mount some battens to the studs to attach it to
Though I would rather have it on the window sill personally
Since even in winter I have the windows open in pc room
Yeah guess he doesn't do much diyI'm surprised too, almost as surprised as he was when his drill bit went through the wall made of cheese.
I think it's a bit strange putting it on a wall with all the air blowing against it, not ideal at all. Spent £1.5k on cooling stuff to nerf it at the last stage (was nerfed already by going Corsair iCue, but that's another story!).
I do zero DIY so good info - but even I reckon that looks like an accident waiting when the drill went from 0 to oops.Yeah guess he doesn't do much diy
Sds drill on hammer lol
Just tap the wall with your knuckles to see
How solid it is first
Usually I push in the thinnest precision screwdriver I have first
To get an idea what you will be drilling into
