- 28 May 2007
Just popped down to the Cinema and got a large.Oh boy I’ll get the pop corn ready. In the mean time please just post RDNA 4 rumours in this thread. You know like the title suggests.
I don't know where this reasoning that Nvidia has "dedicated RT cores" and AMD doesn't, it is not correct, it is not how this works, they both have "dedicated RT hardware" there is nothing emulated about AMD's RT, it is physical.
nvidia also has BVH traversal co-processor which amd lacks, and wider isnt always better in RT, because a deeper BVH lets you reject whole clusters of triangles in a single op, thus saving a lot of work, nvidia seems to have adopted a wider BVH structure for 40 series but there might be something else that goes into their optimization algorithm (nvidia has been leading innovation in the industry, so its reasonable to assume they have a secret sauce)The difference is in how Nvidia and AMD build BVH, this is really over simplified because i'm not going to write a wall of text to explain this, AMD Construct BVH over many branches, Nvidia do it over a very wide tree, this is a bit like 8 slow cores vs 4 fast cores, both can be equally as fast but not by the same method.
The way I understood it (for when RDNA2 launched), was that nvidia had more dedicated RT hardware and they could be considered 'independent', whereas AMD had accelerators for ray tracing and they were not (or were much less so).I don't know where this reasoning that Nvidia has "dedicated RT cores" and AMD doesn't, it is not correct, it is not how this works, they both have "dedicated RT hardware" there is nothing emulated about AMD's RT, it is physical.
The most notable change for the general consumer is that AMD now offer hardware acceleration for specific routines within ray tracing.
This part of the CU performs ray-box or ray-triangle intersection checks – the same as the RT Cores in Ampere. However, the latter also accelerates BVH traversal algorithms, whereas in RDNA 2 this is done via compute shaders using the SIMD 32 units.
The RA units are next to the texture processors, because they're actually part of the same structure. Back in July 2019, we reported on the appearance of a patent filed by AMD which detailed using a 'hybrid' approach to handling the key algorithms in ray tracing...
While this system does offer greater flexibility and removes the need to have portions of the die doing nothing when there's ray tracing workload, AMD's first implementation of this does have some drawbacks. The most notable of which is that the texture processors can only handle operations involving textures or ray-primitive intersections at any one time.
Given that Nvidia's RT Cores now operate fully independently of the rest of the SM, this would seem to give Ampere a distinct lead, compared to RNDA 2, when it comes to grinding through the acceleration structures and intersection tests required in ray tracing.
The advantage of the wide approach is it doesn't really matter which BVH construction you code for you will always get the most out of being wide, the disadvantage wide requires more caching, its why Ada has so much L2 cache, the advantage of the branch approach is you don't need so much cache, but unless you're specifically going to code for that its going to be slower.
Now i's sure AMD's thinking was keep the die size down, it doesn't matter as we own consoles they are going to code for us, hmm... well they don't have to and if the studio is packed with Nvidia cards they aren't going to.
Also, and game that AMD does RT well in must be fake RT, no, not necessarily.
Ah, the AMD defence force arrives.
I was keeping my previous post very simple and even clarified that AMD has some dedicated hardware. What they leave out is hardware dedicated to BVH traversal.
And I don't need you to write a wall of text explaining it. Because I can sum up your wall of text right now. It will be load of technical sounding gibberish basically giving a bunch of excuses for why AMD doesn't perform as well as Nvidia in Ray Tracing.
I'm sorry but this isn't going to descend into a silly argument. Because if you actually know what you say know, you know that there is no getting around the hardware limitation that AMD's solution has compared to Nvidia's. Nvidia's will always be faster. Hence the reason why it's changing for RDNA 4.
And I never said Fake RT either. Where did you even get that from?
I was just about to post the same. Please can we keep this one on track solely for RDNA 4 rumours and info. We don't need anymore Nvidia stuff clogging it up.Oh boy I’ll get the pop corn ready. In the mean time please just post RDNA 4 rumours in this thread. You know like the title suggests.
this has not changed for rdna 3 and isnt expected to change for rdna4, amd doesnt have any dedicated hardware for RT, the intersection tests are also done using hybrid units, it cannot perform more than one of these ops in a clock cycle:
- 4 textue mapping ops (TMU)
- 4 ray-box intersection tests
- 1 ray-triangle intersection test (AMD counts this as one Ray Accelerator op)
source: https://www.reddit.com/r/Amd/comments/ic4bn1/amd_ray_tracing_implementation/
and this can also be corroborated with aggregate numbers: 7900XTX for example has 384 TMUs and 96 Ray Accelerators (4:1 ratio), the ratio must have been the same for 6800XT as well, rdna 4 is not expected to have a big structural change in the pipeline, they are expected to make minor tweaks like the number of intersection tests that can be executed per clock cycle
there's no separate mention of BVH hardware
so in summary they dont have a separate RT pipeline and no big changes are expected in rdna4
Read first line, ignores rest... goes back to reading something interesting.
Nvidia crowd can’t help it but yes let’s get it back on topic.I was just about to post the same. Please can we keep this one on track solely for RDNA 4 rumours and info. We don't need anymore Nvidia stuff clogging it up.
there is a possibility as reported somewhere that they double the RA throughput theoretically and TMU:RA ratio falls to 2:1 in rdna 4 but still the overall architecture doesnt change much and the scheduler has to work extra hard to maintain good utilisation because its eventually a common pipeline and that increases the order of complexityBut with the improvements they were talking about and the secret sauce that Sony is supposedly bringing
It's rumoured to be a fairly small chip, I'm going with XT or just below personally.it will be between RX 7900 XT and XTX performance.
And also have much improved RT performance.![]()
AMD's new GPU can't even outperform Radeon RX 7900 XTX, says leak
The best AMD RDNA 4 graphics card will reportedly be better at ray tracing than RDNA 3, but will still be slower than the current flagship.www.pcgamesn.com
Navi 48 RX 8800 will not be faster than Navi 31 RX 7900 XTX, it will be between RX 7900 XT and XTX performance.
/AMD says hold my beer...You won't be able to charge over $500 for a GPU that can't beat the 7900xtx in 2025
