New AMD Kit arriving need a bit of advice
23 Mar 2011
I was on and off about buying ect for a while, like most waiting for prices to drop or something but finally bit the bullet and have few question, mainly towards motherboard, settled for Asus Rog Strix B650 E-E board and Amd 7800X3d, last time I used AMD was when Athlon come out, yep that long, I know my way round bios and their settings in Intel but AMD is foreign territory, does anyone know if Bios needs to be updated for that CPU or anything? also intresting to hear if there is certain settings in Bios that works better with AMD 7800x3d.
Will be cooled with Artic Freezer III 360 and notice on manual you have option for all in one cable or three seperate to control pump/fans/ vrm fan - which option would you choose? looking at the manual board have enough connections to go separate route, was thinking about this mode if the little vrm fan is to loud or something so I can adjust if is a option
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
5 x 4-pin Chassis Fan headers
Also intrested to hear from anyone who is using the same AIO for 7800x3d.
Thanks
No, it should boot out of the box.
Make sure it has a BIOS new enough that it covers the fixes from the burning issue (which caps the SOC voltage), especially prior to enabling EXPO, but I'd be surprised if the stock BIOS was that old.
Looking at website looks like they implemented from bios 1413 then got some beta and I just presume here 1616 was the last one they mentioned this SOC, then there is 11 newer versions from then on and no further mentioning about SOC, so anything above 1616 should be good
ROG STRIX B650E-E GAMING WIFI BIOS 1413
Version 1413
9.16 MB 2023/04/27
SoC voltage for Ryzen 7000X3D series limited to a maximum of 1.30V to protect the CPU and motherboard.
ROG STRIX B650E-E GAMING WIFI BIOS 1616
Version 1616
9.19 MB 2023/05/16
"1. Update AGESA version to Combo AM5 PI 1.0.0.7.a
2. Support 48/24GB high-density DDR5 memory module.
3. Memory QVL amended to account for AMD 1.3V SoC voltage limit.
4. EXPO/XMP prompt notice removed.
Before running the USB BIOS Flashback tool, please rename the BIOS file (SB650EE.CAP) using BIOSRenamer."
Be prepared for memory training on first boot. There is a BIOS setting to prevent the training on every boot. There's a thread somewhere in the memory or motherboard forum.
Also read up on the PBO settings. I tried tweaking but left on default. I don't game so CPU (7950x) rarely gets near 100% util.
Just a had quick look on Asus website and looks like You need to enable EXPO and subsequently enable Memory Context Restore, Thank you for the heads up regards this as I would panic at boot
I will be mainly using for MSFS so will take a look but at first will try default been honest, PBO is that about under volting ect.?
Yes, I panicked a little and thought I had missed something. The orange LED was on for ages. It still comes on every now and then and you just need to let it do its thing.
I found this series of videos useful for explaining the settings and how to tweak them.
The ASUS ROG Strix B650E-E and AMD 7800X3D are a solid choice, and you’ll be in good hands with that combo. Regarding your BIOS question, it’s worth checking if the motherboard’s BIOS is up to date to ensure full compatibility with the 7800X3D—most newer boards ship with the necessary updates, but it’s always best to confirm before you start. As for BIOS settings, enabling AMD’s Precision Boost Overdrive (PBO) can help you get the most out of your CPU, but make sure to monitor temps, especially with the 7800X3D. For cooling, your Arctic Freezer III 360 is more than capable, and since the board has enough headers, I’d recommend going the separate route for more control, especially if you want to fine-tune the VRM fan if noise becomes an issue.
No Internet connection, but found solution on net, only strange thing was I had to run batch file first then restart otherwise I was getting error driver not supported for this windows.
Just to add I'm actually connected to LAN.
Is this common on AMD or is down to motherboard manufacturers?
Yeah I'd probably go seperate. I've never seen an "all in one" cable before lol. But seperate is more advantageous as you can lock your pump to ~75% and then have the rad fans on a curve with perhaps a delayed step down. :)
PBO is overclocking. Let's the CPU boost at higher frequencies. I've only used Curve Optimiser to optimise the chip (undervolt). You can install Ryzen Master and let it do it for you. Takes like 45 mins or so to run through. You can then take the value and hard code it into the BIOS if you like. :)
When I had the AFIII I used the separate header cables so I could control them independently, on cheaper boards you might only get one CPU header which is where the one cable is ideal.
Using Arctic LF III 280
one cable header is perfect. Never hear VRM fan or pump over the fans
have many fans that occupy other fan headers anyway
I have seen video regards this somewhere, will need to take a closer look in coming day or two.
I need your help, windows installed, all drivers updated, latest bios.
Enabled Memory Context Restore and once in windows about 30 sec later I get blue screen Memory_Managment error.
Was on Auto, post screen in35sec full windows about a min, once changed to enable yeah 14 sec in to post screen then I was in windows at 36 sec. Fair bit difference but blue screen
I'd leave it off for awhile just to confirm that your PC is definitely stable "as is".
I found the problem now, there is 2 settings that needs to be changed, Context Memory Restore and Power Down or something like that, works fine now, ram running at 6000 and also went with Negative 20 on curve optimizer, will run like that for now then see how it can go bit higher on it
Well I almost forgotten this turned out OK for a simple build, wasn't bad attaching the Artic to mounts, not sure what all the fuss is about when you read online, as I don't see the case is budget friendly Montech 903 Base and in all honesty is not bad, was expecting worse for that price, still waiting for my corsair 600w gpu cable so should arrive after bank holiday and I am very impressed with preformance of that build so far.
