Quick question:
With Octopus now and have been for years and staying with them whatever.
Fixed deal ends Oct 15th (with £150 exit fees), however they have told me about their 49 day rule, which means as soon as my Smart Meter is installed on the 13th of Sept I can set something new up.
I'm a low level user of both Elec and Gas - I'm intruiged by the tracker and agile tariffs (yes I'm prepared to risk the ups and downs) - but what do you think would be my best option?
Tracker is a slight gamble IMO, its likely to be lower price most of the time. There is tiny risk of a large price rise but you can come off tracker. IIRC its got a 9 month cool down however so you really need to be certain to come off it.
Agile is very different, 30 minute pricing. Can vary a hell of a lot day by day. So its not just about low/high user, but also when.
Take a look at this and you can flick back day by day to see the pricing.
Agile Dashboard
View current and future Agile Octopus tariff rates for your region.www.agiledashboard.co.uk
I would say the real target of agile is to avoid completely or minimise usage on 4-7pm
You can also have a play with https://agile.octopushome.net/compare-your-consumption options very top left
Right thanks.
I'm not someone who is going to run my life around minimising usage at the peak times, and that window is most likely to be when I'm at home a lot anyway. So I think my best best is the tracker option - I'm assuming there's trackers for both G and E?
Could it be worth it to go on Agile instead of Intelligent Go when I get my EV? The reason I ask is that while the overnight rate becomes 7.5p, the day rate is higher than I'm currently paying on tracker. Does Agile tend to beat or match the 7.5p IG overnight rate anyway?
Often when agile is cheap some of the cheapest slots are in the 1pm-4pm times.Or there is possibility for beating 7.5p at some times during the day?
IOG is 7p now, btw.On average it does not beat the 7.5p offered by IOG in the overnight slots however if you dont need to charge everyday the chance of picking up cheaper units is higher. The agile day rates outside 4-7pm have been on average well below the IOG day rate.
You can see average prices in each slot for the last year here https://energy-stats.uk/octopus-agile-southern-england/ just change your region.
If you use many units in the 4-7pm slots you will probably be worse off, sometimes it spikes a lot higher. Last winter it got up to about 60p, potential to go much higher in a prolonged cold spell.
For me without a battery agile would be too much hassle.
Wow that's good tool. I'd have saved £7 on Agile over 8 months compared to tracker, so not worth it for me.
Could it be worth it to go on Agile instead of Intelligent Go when I get my EV? The reason I ask is that while the overnight rate becomes 7.5p, the day rate is higher than I'm currently paying on tracker. Does Agile tend to beat or match the 7.5p IG overnight rate anyway? Or there is possibility for beating 7.5p at some times during the day?
My electric meter has been broken for months, unable to get readings ...interesting conversation coming up with Octopus on average rates and usage charge![]()
One of ours is a bit iffy, will stop doing readings for a few weeks and then comes back online. The average tracker rates seem fine anyway, we don't really increase usage on cheap days.My electric meter has been broken for months, unable to get readings ...interesting conversation coming up with Octopus on average rates and usage charge![]()
How come it has been left like that for so long.?
Our gas meter is being changed as I type this, by Morrison on behalf of EDF. It has taken two months or so of continued emails and finally escalated to complaints before this has happened.
Both of gas and electric meters are SMET 2
I only noticed it when I took a look at my bill - "Estimated". Went and had a look, its stuck on some screen saying Initialising. I believe it's the V1 of the smart meters, so doesn't surprise me. In addition to that, my Gas meter has always had issues connecting to it, so I'm hoping this will be a replace both job and finally have them both working properly.One of ours is a bit iffy, will stop doing readings for a few weeks and then comes back online. The average tracker rates seem fine anyway, we don't really increase usage on cheap days.
'Worries' with supply in Norway and around the world coupled with heightened geopolitical risk are pushing prices higher. Also hedge funds https://energynews.pro/en/hedge-funds-add-to-european-gas-market-volatility/Anyone know why gas is going up? Demand must be pretty low at the moment with it still being summer.
Moraig Lyall, chair of the environment and transport committee of Shetland Islands Council, said annual household bills in the islands were often more than double the UK average of £1,700 and showed no sign of falling as a result of hosting Viking.
"People look out their windows now, they see all these turbines that are generating lots and lots of energy, but they're not seeing the benefit here.
