- 29 Aug 2010
- Cornwall
So can you buy decent 12VHPWR adapter cables, like the ones you get with some 4000 series cards?
I see lots of the cables for specific PSUs but are there any that you can just plug 6/8-pin PCIe cables into?
I see Akasa do one and it's a right-angle one, which seems like a good idea, except it looks like it would be impossible to remove as you wouldn't be able to reach the release tab.
which '4070' was it
