I may do a clean install of the 24Hs ISO using the Chris Titus utility that removes all the bloatware apps and useless legacy services.
funny you say that..i was considerign the same, dont think i will atm, but its food for thought mate!
Pointless. Just run the VDOT script and install anything you want with winget or chocolatey. I have a single script that will take any Windows version, dynamically install any drivers, add a network profile, install chocolatey and any apps I specify, and deep Win32 apps like Office or Adobe, configure users, configure ENV path, run the VDOT optimisations, add MSFT baselines and reboot. Takes about 20 mins to run and I don't touch a single key or mouse click other than boot to USBI may do a clean install of the 24Hs ISO using the Chris Titus utility that removes all the bloatware apps and useless legacy services.
If you're going to use Mircowin using his utility to debloat the ISO, it's great apart from the fact it also converts the windows explorer UI to some win 10 version. I tried to convert it back to win11 UI but no luck.
If you don't mind that then it's great, gets rid of all the MS bloat.
It's pointless when there is a single script available which does all this for you and is remotely hosted, by Microsoft themselves.Not pointless. It shaves off a lot of legacy crap, Removes all bloatware and preinstalled things and even lowers CPU usage and lowers memory usage by a few gigs.
Well no, as that contains all the bloat. The ISO image from MS is the very definition of the thing we are trying to avoidOr just use a iso image.
Well no, as that contains all the bloat. The ISO image from MS is the very definition of the thing we are trying to avoid![]()
If you want to take the risk of someone else creating a debloated ISO for you, and you are confident in it's source and what's really really really running on it, then go for it.You can get debloated isos.
Just to humour you, I checked. I picked a random image. I can guarantee it's not fine. The one I found had a hidden keylogger on itIt's fine.
It's pointless if you know what those things are. A French phrasebook is pointless if you are fluent in French.Pointless. Just run the VDOT script and install anything you want with winget or chocolatey. I have a single script that will take any Windows version, dynamically install any drivers, add a network profile, install chocolatey and any apps I specify, and deep Win32 apps like Office or Adobe, configure users, configure ENV path, run the VDOT optimisations, add MSFT baselines and reboot. Takes about 20 mins to run and I don't touch a single key or mouse click other than boot to USB
Could you provide a link please ? Sounds quite usefulIt's pointless when there is a single script available which does all this for you and is remotely hosted, by Microsoft themselves.
I am still running 23H2 and I'm happy to do so until this update is pushed for me, guessing their could be some issues still outstanding.
Noting what has been mentioned about debloating Windows, is Microwin designed to be used after a fresh install of a regular Windows 11, rather than change the ISO..? Or does it seem to be like Nlite in creating a reduced form of an ISO..?
It has been a long time since I considered looking at anything other than a regular ISO Windows install and use, remembering that at one point removing "too much" can have consequences that might not be immediately obvious, in previous Windows versions...!
