- 19 May 2010
- Cheltenham
Number go up.
Along with pricing.Number go up.
Not at all. There are many people using 4090s who are utilising all the vram, and want more.He only skimps on low and midrange cards high on cards its full on overkill. Its more to do with marketing than usefulness
I’d always want more VRAM even if it’s too much for current games as new games come out with increased VRAM requirements.See all the gaming benchmarks with those lovely on screen benchmarks and I can’t see why you’d need this much VRAM?
16 is enough isn’t it
It’s been said that the 5090 might be 2 to 2.5kI’d always want more VRAM even if it’s too much for current games as new games come out with increased VRAM requirements.
That being said, the 5090, 4090 and 3090 are all mostly cut down workstation GPUs with pro-sumer use cases and things like error checking removed.
Nvidia quickly figured out that people would be willing to buy very expensive graphics cards for gaming so they made another segment above the previously top of the range 80 series.
Anyone remember the 8800 Ultra or 480 or 780 being the top of the range and seen as really expensive? Seems affordable now compared to a £2000+ 4090 series.
Use or allocate? Typically only modded games would ever use that much VRAM.I’ve seen plenty of games use the whole 24Gb on my 7900XTX. Doubt it’s all really needed, but a flagship card should be overkill imo.
For Nvidia, Memory is cheap as chips as they get deals in bulk, But more memory means they can put the price higher and higher.
Personally I don't care.. I want as much of a vram buffer as possible and for games to stuff as much of their assets into to it to further enhance the overall experience. Currently playing Diablo 4(UW1440p) a bit and that will eat up almost the entirety of my 16gb of vram but it is also ohh soo silky smooth.Use or allocate? Typically only modded games would ever use that much VRAM.
Did a 3090 need 24? It’s an overkill product, with overkill specs. Somewhat helps them justify the crazy pricing.
Adding $20 more VRAM to a 4060ti then proceeding to charge $100 extra, Nvidia knows what they’re doing.For Nvidia, Memory is cheap as chips as they get deals in bulk, But more memory means they can put the price higher and higher.
Obviously you want enough VRAM so that the game isn't swapping active textures, but looking at allocated isn't a measure of usage/that a game would run worse with less.Personally I don't care.. I want as much of a vram buffer as possible and for games to stuff as much of their assets into to it to further enhance the overall experience. Currently playing Diablo 4(UW1440p) a bit and that will eat up almost the entirety of my 16gb of vram but it is also ohh soo silky smooth.
There're both at it as AMD did something simillar with the 7600XT 16GB which cost $60 more than a 7600 8GB.Adding $20 more VRAM to a 4060ti then proceeding to charge $100 extra, Nvidia knows what they’re doing.![]()
Must be friends with Apple. $200 for 8GB of RAM.Adding $20 more VRAM to a 4060ti then proceeding to charge $100 extra, Nvidia knows what they’re doing.![]()
Along with pricing.
99% of the reason I'd buy tbf...Along with my epeen
