nvlddmkm event crash whilst watching video on a 4080 Super
11 Dec 2008
London
Recent got a B Grade Asus RTX 4080 Super due to a great offer from @Robbie_G (thanks @Robbie_G)
But having a really weird problem with it.
I get driver crashes (not BSOD, but machine unresponsive for 15-20 seconds) and get this message in Event Viewer.
Code:
The description for Event ID 153 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\000000df
Resetting TDR occurred on GPUID:500
The message resource is present but the message was not found in the message table
when watching video. It's not every time, but definitely not a one-off.
I don't get this gaming or under load, just watching Amazon Prime Video on Edge, which shouldn't break a sweat.
I've run DDU to remove my previous driver (AMD 6900 XT) and nothing else seems to be having a problem.
I have tried with both RTX Super Resolution enabled and disabled. Doesn't seem to make a difference.
GPU utilisation between 1 and 6%.
Also seems worse on Edge than Firefox or Prime Video for Windows.
I've obviously Googled this as well, but it mostly returns:
- bad drivers (freshly installed drivers),
- bad RAM (never had problems with previous card),
or - bad card (it is B Grade but didn't seem used and honestly, it's just odd that it's a problem with video and not gaming)
3x monitor setup
4K 144hz
1440p 60hz
1080p 60hz
Other HW accelerated apps - probably browser, Discord. It's also not all video, like, YouTube so far is fine. Just seems to be mostly Prime Video. I'm wondering if it's some nVidia based decoding or nVidia DRM.
Can you turn of hardware excelleration to see if that helps. I know it’s a pain but I would also try using just one monitor to see if that helps.
problem is on all monitors, the driver just crashes and then machine goes unresponsive until it recovers
Just for clarity, the reason myself (and I assume) eeii mentioned not using three monitors simultaneously is because multi monitor and multi refresh can change the GPU's management of power states (as can having hardware acceleration enabled in browsers, Discord, etc), so it is a process of troubleshooting if the card is having problems managing these power states and changing the clocks, voltages and power usage. If the power usage is high at idle, you could also try having the fans spin up.
I guess what I'm trying to figure out more is... is this likely to be some bad nVidia driver or otherwise software interaction that might resolve itself with a later driver fix/browser update.
Or, do I have a hardware fault where it's a good idea to try and do a return given the reduced warranty window of b grade stock?
If the card has problems with switching power states with hardware acceleration or in multi monitor/multi refresh, it is often something that you can fix by fiddling with it, but that fix would likely have to be applied permanently and I guess you could call it a (V)BIOS bug.
If there's no fix that works and it keeps chucking out driver errors, then my guess is that is why the card was returned, but it was not tested in the circumstances that causes it.
I would suggest you try it with a fresh install and absolutely nothing extra installed though, just to rule out that you aren't having dirty driver problems.
What is the exact model of your 4080 super? Have you used GPU-Z to check how recent the firmware/bios is?
I'm really trying to avoid doing that. A fresh install is a pain.
I did this, and now I can't really reproduce it. I had one more crash, but not whilst in video.
Was that with hardware acceleration disabled in your apps, or just a single monitor plugged in?
Can you use something like hwinfo sensor tab (GPU-Z might have this detail too, not sure) to expose the clocks, power usage and temps at various points? You may find a link.
I know, but sometimes it is the only way to be sure.
