Obviously a coke addiction... How people drink enough fizzy is beyond me though!Falling on hard times Lee?
I'd be tempted for that£350 a month sounds better!!
Do you even antenna, bro?*puts tinfoil hat on* Not sure Id want all that radiation coming into my house
Sounds like Ionica; was reasonably popular around here and you still occasionally see houses with the octagonal antenna mounted to the side of the house.I remember a lot of people in my area ending up with those funny little telephone receivers on the sides of their houses for many years after the company that fitted them went bust, although that was a different thing as it was something to do with a telephone service. Now I've remembered it I can't for the life of me remember the name of the company, or find anything about them on google![]()
That's the one, I think about 5 houses on my street had them at one point and I seem to remember the last one only going down a few years back when one of the houses had it's sofits etc replaced.As others have said, you would need to make sure it could easily be removed in the event of a house move or the business fails.
Street lights are far less permanent than houses and it's far more likely to get damaged or disturbed on a street light with little warning as they're relying on both the council and all it's contractors and subcontractors to remember/be aware of what it is and that it needs to be replaced if any work is done to the street light, if it's on a house (especially a new build) they can be fairly sure it's not going to be disturbed for potentially 10-15 years minimum (and it's probably easier/cheaper overall).Didn't the developer rush to get your house finished?
I'm going to guess they forgot to install this in a mast somewhere, like why would they not just stick it on a street light?
<snip>I've decided not to go ahead.
I'm not sure what the terms are
Just bought his amulet. Fingers crossed it works.Russell Brand can fix that for you
