Note to self: Hide the chunky Virgin Media remote control from @LuckyBenski if they happen to visit.You're not supposed to insert it!
*But it does have a suggestive shape
Looks like a vine weevilWhat bug is this?
Thought it may be a weevil. It dropped out of the attic...Looks like a vine weevil
Really hard to crush, tough gits.Thought it may be a weevil. It dropped out of the attic...
It's a weevil (family Curculionidae) in the genus Sitona, possibly Sitona lineatus, one of the most common Sitona species. The beetle only wound up inside the house by accident, you can put it outside.What bug is this?
Never worth rushing these things, takes time to do a job well.I just replaced the toilet roll holder in my ensuite that's been broken for about 6 months!
Funny thing is it took like 5 minutesNever worth rushing these things, takes time to do a job well.
Because you planned it well over the last 6 monthsFunny thing is it took like 5 minutes![]()
I had a similar issue with really quite expensive ubiquiti gear (relatively speaking). Do check the 5ghz band. Mine was set to 40mhz but changing it to 80mhz got me to 400mbps.Spent the day testing/comparing the Toob provided router (Linksys Velop MX4200: Wifi6) with the WiFi 7 TP-link I picked up recently...
...and now my WiFi speeds are absolutely appalling, compared to a wired connection.
I understand that wired will always outperform WiFi, but I'm struggling to understand how 40-60mb download on WiFi, with my pretty decent phone (OnePlus 9 Pro), on the 5Ghz, is acceptable compared to 900/900 wired.
Have factory reset both routers to no avail: WiFi doesn't get over 60mb on any device.
