Thinking about doing some guttering and drainage improvements around my house
Was hoping to get it all done today but only got half way.
There is 2 inch of water in my subfloor area that I could see through the airbrick hole. Is this normal or a concern?
Airbrick removed but many loose bricks as well.
New bricks and airbrick, and repointing of the left side.
The water is a concern, likely because of the air bricks being level/below the floor level.
Not much you can do now though, but it might go stagnant and smell till it dries out which may not be for a while now in this weather
It may/may not be an issue,
Excellent job though
This was a rough job. Three near full days it's took, fiddly airbricks, lots of uneven joints to be deep filled (old mortar was just powder).
Right side airbrick.
Finished job:
Just got to re-caulk the windows now and get some upvc trim for the edges.
It's a shame I couldn't also get rid of that middle airbrick but will have to wait. A) they've wedged the door sill onto it, and b) it's got a central heating drain through it that goes under the floor of the room behind those french doors. Will have to wait till I get under the subfloor in that room then decide what to do.
Good job all round. Are you using lime mortar rather than cement?
No I'm using 5 building sand to 1 cement. I did research lime mortar but it seems very mixed opinions on whether it's needed on anything other than a very old stone building. May be a bit of a fad thing I'm finding. I've gone standard cement mortar with a drop of chemical plasticiser.
