Hell I'm a C now and enjoying it - the level in C now is higher than last time I was here... I'm doing better numbers, the racing is tougher and harder, really do not feel like I'm sandbagging like last time! Actually dropped myself out of my ZRL team (although still captain) as a friend in a C team got promoted to B, so we switched position. I've been a
workhorse there in the TTT (my main thing I ride), contributing to the
Team win on the first Scratch race with a 4th, then annoying had a zwift/bug technical last week for the points race and didn't make it in (as a punchy climber really would have suited me)... So had a point to prove on the Scratch race this week...
Only went and won it! Somehow a 4.1w/kg for 5 mins still didn't get me a B promotion!
<snip>
But that puts me in the '3rd' group around the higher-middle (350-520) which I guess is high C? Somewhere near right, I'm not very often doing near 3.5 for 20/min.
Only went and
smashed some power out in a Ladder race last week too... Then on the Wednesday noticed WTRL had me back up to Cat B. ZP I was still a C, then by Thursday I'm showing there a B again too! vELO back up to 1271 (from 1255) Ooops!
So I'm back into B2 for ZRL again next round, as both our 3R teams are in B2 divisions. Damn! Would be nice to get some lower B cat racing but no option in the timeslot I want with EVO! Needless to say I'm not going to be winning anything again anytime soon... My zFTP at 3.245w/kg
Oh, here's a question. At the bottom of the rider list on the right hand side of the screen, Zwift will say "+20 in group". That value doesn't seem to change (especially during a race), so what group is it actually referring to?
Yeah as mentioned - that shows riders 'signed up' to the event on Zwift... Not the 'actual' in the event when it's started. Pretty pointless! It will sometimes change - but really only in group rides when riders late join.
Good news though - my ZRS has gone up from 355 to.... 357
My ZRS now up to 472! How can you tell a 'history' of it to see your changes?!
Zwift is virtual training for running and cycling. Smash your goals and compete with others around the world. With structured workouts and social group rides. iOS and Android compatible. Trusted by the pros. Try free for 14 days.
www.zwift.com
Anyone know of any downside to using a really old crappy bike as a turbo bike?
My dad has a rust bucket of an old Focus Hybrid bike. My plan would be to combine with the Zwift Hub, so in theory all i need is the frame/handlebars and cranks. The size is decent for me and so i can't think of a reason not to use it really. I've some spare Tourney crankset that i could use if i needed to change anything.
Downsides are the fit/comfort (bars/saddle/geometry). The noise from the drivechain and any shifting. Zwift Hub? I thought that was discontinued, as was the Cog. Or is that now the Zwift One. Can't keep up with their naming!
So you buy the Cog and fit it to a Core and that makes it a Zwift One. But if you buy it with the frame it's a Zwift Ride. I think!?
question to those with wahoo trainers and zwift, anyone know how this works exactly?
I set my trainer in wahoo to :
egr power smoothing on
egr mode speed simulation off
is this correct, what do you use with zwift - and do these settings even matter in zwift?
I find that I often spin out and say freewheel results in me just spinning "nothing" my power drops to 0 and my resistane is 0 too from the trainer until I catch up, this seems to keep my RPM quite high - 100+ average, compared to real world riding of around 85-90 which is where I'd like to be. - trying to figure out what I should set on zwift to get a better feel, my thinking is egr on would allow me to spin slower and produce same watts without having to constantly flick between virtual gears.
another question, trainer difficulty, my current is default 50%, from what I read on zwift, 100% simulates real climbs etc best, 50% makes it a bit easier, but what's the general, do we just leave it at 50% or increase it to max for "real world" feel?
How it works, and when to use it.
zwiftinsider.com
Maintain power levels when transitioning from seated to standing efforts.
zwiftinsider.com
ERG more is important for riding training intervals/sessions - basically the trainer providing a set 'resistance' for you no matter the gear you're in, so you can meet the power target. The smoothing will help you for longer sets, but short intervals it'll do the opposite. I don't even know what speed simulation is...
For racing & 'free ride' type stuff on Zwift - where you want the trainer to be controlled by the environment, then it'll not be in ERG mode. Think they call it 'SIM' (simulation) mode. Don't know if your second setting does something with that. It might be totally superfluous for either on Zwift.
Don't worry about Trainer Difficulty - treat it as more 'gearing' or smoothing of gear changes. It's really how much you 'feel' gradient when you encounter it. 100% means you feel it all, default on Zwift is 50% so when you hit a 10% climb it only 'feels' like 5% - from a gearing and effort perspective.
Lowering difficulty means you feel very little, you should need to change gear less when trying to ride smooth power and encountering gradients - although your progress on screen will slow more. Setting the difficulty higher should make it 'hurt' more - you'll need to change gear more to keep speed/effort up, but by 'feeling' more of the gradient you'll benefit from changing gears more. For me (being fairly punchy) it gives me more of 'ramps' to launch off, or more effective surges when I make them. But also as I ride a bunch of TTT's where the smoothing of a lower difficulty helps more... I tend to ride with it around 65/70% rather than changing it all the time. Lots of smoother TTT teammates are running it at 30-40%.
Confused by this setting? Here’s a complete explanation.
zwiftinsider.com
Dig into the most misunderstood and controversial setting in Zwift’s menu!
zwiftinsider.com
