- 19 Oct 2009
Never had a blower cooler that I didn't have to replace after a year or two. Arctic Cooling were life savers in that regard: quieter & cooler.
4090 fe does that, rear fan sucks in and blows out the back, next fan is just passthroughAttractive? No, that's weird and you should be ashamed of your kink
But there is something to be said for exhausting hot air out of the case asap, a blower/passthrough hybrid could work well, perhaps send heat from 1 or the other out of the case and have passthrough for the other.
i did this for an old nvidia mx440 and it was artic.Remember buying third party heatsink for ati 1800 replacing the blower then using a couple of 12cm fans
Possibly made by artic?
I had one of these, well the earlier metal design, and its a single fan so it has to ramp up to high speed to shift any kind of air volume plus it can only go in one direction, towards the back so honestly it was inefficient (it got hot especially in spots) as well as being very noisy. I wouldn't have one again
Arctic Accelero Xtreme 3 fans yeah, had one of these and boy did it make a difference to noise and temps. Bit scary taking the thing back to a bare PCB and making sure the VRM's heatpads mated up to the heatsinks (needed to double up on occasion)Remember buying third party heatsink for ati 1800 replacing the blower then using a couple of 12cm fans
I had an artic cooler on an x1900xt, but it was one of those coolers that was blower like with a larger fan at one end.
Ed: one of these:
The the accelero X2 cooler came along and later the larger coolers you could strap multiple fans on.
I always liked blower cards. 1080Ti FE is probably peak blower.
They were always loud, but useful in SLI setups, and also particularly good for small ITX builds.
Some lower end cards like a 4060 could easily be a blower without thermal issues.
The gtx 480 just looked so raw and one of the best designs for a blower card, looks-wise, anyways
You can't beat some variation of a Zalman copper monstrosityI think some of the blower cooler designs are very nice, though some look bloody terrible. I think some of early/mid 2000s red ATi coolers looked rather tasty.
I wouldn't hold my breath, as I think the days of blower cards is overHell yeah totally agree, those versions of 1080 Ti and GTX 480 just have an awesome look to them. I'm hoping for a throwback style RTX 5070 in the upcoming launch, something that looks cool and a bit retro, bored of the same triple fan behemoths that modern GPUs have.. (Mind you they do cool well lol).
