Shame they didn't test above 1080p though to compare.
So not too much difference then? Bit disappointing really, but I guess you're limited as to the impact a CPU can make at 4K.
From what I've seen in reviews, for the most part it looks like an X870 board isn't necessary, unless you want the absolute best/bleeding edge.One is becoming tempted by this chip as an upgrade to my 5950x. It's not going to be cheap though.Is it worth going for an X870 board or just overkill for a straight gaming machine?
Hence why reviewers never test a CPU using 4K gaming. It doesn’t tell you much.So not too much difference then? Bit disappointing really, but I guess you're limited as to the impact a CPU can make at 4K.
It can tell you it's not overly worth getting. Guess it depends what narrative the reviewer is trying to spin. Why not go down to 720p or 480p, surely that'd make it look even better?Hence why reviewers never test a CPU using 4K gaming. It doesn’t tell you much.
Sure thing. Just to make the CPU look ever better. Makes sense /sIt can tell you it's not overly worth getting. Guess it depends what narrative the reviewer is trying to spin. Why not go down to 720p or 480p, surely that'd make it look even better?
isn't that what they're doing by testing at 1080p?Sure thing. Just to make the CPU look ever better. Makes sense /s
Yeah, as much as I love shiny new things, there's really no compelling reason to get one over my 7800X3D.So not too much difference then? Bit disappointing really, but I guess you're limited as to the impact a CPU can make at 4K.
It also depends on what you'd be 'coming from' (assuming gaming is important) e.g. if someone is running an AMD 3600x or older, at ANY resolution (with an decently capable graphics card) the user will see a MAJOR uplift in overall framerate and a HUGE uplift in the minimum framerate etc.It can tell you it's not overly worth getting. Guess it depends what narrative the reviewer is trying to spin. Why not go down to 720p or 480p, surely that'd make it look even better?
like if you don't already know? if the cpu is not affecting the result then my guess is that it would be SFA, shocking that.On the contrary, it tells you what you need to know if you game at 4K.
Both sets of data are valuable.
They are trying to highlight the performance differences if that’s what you mean.isn't that what they're doing by testing at 1080p?
3D cache is an insulator, so it's not like it gets more heat, it's that it stopped insulating cores. There's whole articles out there where AMD employee describes all the bits and pieces they had to do with TSMC to get here (flip the cache to the bottom was one step, but not the only one, they removed loads of insulating silicon in general), from the chip. AMD also finally clarified that in case of older generation it wasn't cache that could've overheated (so interwebs were wrong) but cores, hence they had to lock them down to prevent frying. Cache isn't very affected by heat, it seems.They flipped it around so x3d cache gets more heat instead of the cores
I want to see more reviews where the CPU is held back by a huge GPU bottleneck at 4k. The bigger the bottleneck the better so every CPU performs the same.
But the fact every cpu performs the same, but the price can vary wildly, is really important real world information. It could save someone spending hundreds more than they need to. Not everyone is as well informed as enthusiasts.
