I might have misunderstood your post earlier, did you want me to walk around the big fishes?Can you please test with PT on (all other settings maxed out), 1080p w/ DLSS Ultra Performance in this scene?
AMD Ryzen 7 5800X 3D Cache Eight Core 4.5GHz (Socket AM4) Processor - Retail - Go Go Go xD
Ok maybe not a problem, but I'd be more comfortable if my temp was in the 80s, no matter what the load was. However, I worry too much, and I'm not likely to be calculating prime numbers:)forums.overclockers.co.uk
I found the area and snapped a few screenshots. Generally if walking round that circle FPS were in the 130+ or so.
I can probably record a video if you want. This was at 1080P, with Path tracing, every setting maxed out but using DLSS Ultra Performance, frame gen off and ray reconstruction on. Crowd high.
Looks garbage!
I forgot to update my overlay, just realised. Not using a 9950X but a 9800X3D. I'll change that now in case i do more screenshots or a video.
