The information is right there for you to decide - do you really think it is useful having results of a supposed CPU comparison with all the CPUs getting the same FPS because everything is GPU limited? Most people who don't need to upgrade their CPU won't upgrade it just because HUB says it is 10% faster at 1080p. But this is an enthusiast forum and we are fans of blowing money on frivolous upgradesI think that the reviewers are telling us which is best rather than presenting the information and allowing us to decide. FPS at 1080P isn't the only metric I use to decide so I have to try to ignore what they are saying and consider all the options myself.
I play at 2160p but I still want to see CPU bench results from reviewers where the GPU is not the limiter.
 I'm not sure if that is something the devs have been too lazy to fix or whether there are genuine reasons for it - unlike some people have suggested it isn't just a loading screen which they were too lazy to label properly and just says shader compiling as if you run the game on a system without enough memory to compile shaders it almost immediately loads the game but you get quite a bit of stutter when playing.
