What watch do you wear?
So I dug a little in to all of this before posting on here originally. I asked Cw Sellors (supposedly the original sellor of this watch)
They have just got back to myself stating they were concerned as to why one of their authorised pieces were being sold on eBay….
Turns out the 2 serial numbers were a match and is exactly how it’s supposed to be, however the watch is stolen! Spoke to eBay too and have assured myself of the refund and Cw Sellors now need to regain possession of the returned watch.
How does anyone steal a 4.5k watch nowadays from said jewellers?
I absolutely would think it could get through - how would eBay staff know what to look for in a watch like this? I don't think there'll be training for all brands, and even if there is, it's a bit of a push to imagine eBay putting people through this training, let alone then having them assessed to see if they have actually learnt the ins and outs. They didn't even spot the serial numbers not matching... doesn't exactly indicate any attention to detail does it!
Rolex fakes/frankens can be astonishingly convincing to supposedly trained Rolex specialists, and that's a brand that's been around for yonks.
You've definitely done the sensible thing in returning it.
Hahaha, eBay don't train staffers to authenticate things, they outsource it. For watches I believe it's Stoll and Co.
What did the seller of good repute say about it being stolen?! :S
I don't think the OP would have thrown that at them. Rather pointing out the serial number non matching issue should as well as seeing it IRL change of mind stuff would have been enough
Could be an insurance fraud rather than a "stolen watch". I can't say I haven't thought "this is quite an easy way to make £7k". I wouldn't then go and sell it on eBay though, to be fair :cry: #ethicalcriminal.
Edit: this is assuming it wasn't stolen from CW Sellors but CW Sellors checked the stolen database and just informed OP.
I put on my automatic for my work Christmas do on Saturday and haven't taken it off since. Apple Watch is just on the sideline now! Actually haven't missed it at all.
I have 2 steinhart; one, the Premium Blue, stopped working just outside the warranty period...
The second one, the Premium Titanium one got a knock, the bezel popped off all bent and I realized it was made of... brass. Not titanium (and also had corroded inside).
I replaced it with a 200 quid Aliexpress "Octopus" tudor semi-clone that has been a *lot* better as a trashable watch! Needless to say, not planning any Steinhart purchase anytime soon :-)
Where were you when I was doing research over a decade ago? :p
It’s been working fine since and stupidly accurate like a quartz.
Designing a new mechanical wristwatch movement requires a balance of tradition and innovation. Below is a conceptual plan for a unique mechanical watch mechanism that blends traditional watchmaking principles with modern, creative twists.
Design Overview: "Heliomax Movement"
A high-efficiency, skeletonized mechanical movement featuring a novel solar-enhanced mainspring recharge and a visible double escapement system.
Core Features of the New Design
  1. Solar-Infused Energy System
    • While the movement is primarily mechanical (hand-wound or automatic), an integrated micro solar module placed under the crystal assists the mainspring.
    • The solar cell absorbs energy to provide additional tension to the mainspring via a micro-actuator, extending the power reserve.
    • Why: Increases efficiency without relying fully on quartz/electric systems. Keeps the movement traditional but enhances endurance.
  2. Double Tourbillon Escapement (with Two Independent Regulators)
    • Two visible, synchronized tourbillons regulate time more precisely.
    • Instead of working as a single system, these tourbillons independently compensate for positional errors caused by mavity.
    • They are located at 12 o'clock and 6 o'clock for aesthetic symmetry.
    • Why: The double escapement design offers visual complexity and precision, perfect for a luxury mechanical movement.
  3. Open-Barrel Skeletonized Design
    • All moving parts (gear train, barrel, escapement) are exposed through a fully skeletonized base plate and bridges.
    • Skeletonization improves aesthetics and reduces the overall weight of the movement.
    • The gears would feature spoke-style wheels for a modern, airy design.
    • Why: Provides visual beauty, a lightweight structure, and a clear view of the mechanism.
  4. Modular Power Reserve
    • A modular barrel design allows watch owners to add or remove power modules (secondary springs) to adjust the power reserve manually.
    • By default, the mainspring will have a 48-hour reserve, extendable up to 72 hours with optional modular springs.
    • Why: Adds customization for watch enthusiasts who value control over their timepiece's reserve.
  5. Hemispherical Balance Wheel
    • Instead of a flat balance wheel, the design incorporates a 3D hemispherical balance wheel.
    • This reduces air friction and allows for better amplitude adjustment in all positions.
    • Why: Innovates on traditional balance wheel mechanics to enhance precision.
  6. Hybrid Winding System (Rotor + Crown)
    • Automatic winding via a rotor combined with a traditional hand-winding crown.
    • The rotor itself is skeletonized with a curved weight to allow for better rotational efficiency and aesthetics.
Material Innovations
  • Base Plate and Bridges: Grade 5 titanium for strength and lightweight structure.
  • Balance Spring: Silicon hairspring for anti-magnetism and temperature resistance.
  • Escapement Wheel and Anchor: Diamond-coated silicon to reduce friction and improve energy efficiency.
  • Gears: High-grade stainless steel with anti-friction coatings.
Visual Appeal
  • The dial side prominently displays the double tourbillons and the hemispherical balance wheel.
  • The rear exhibition caseback reveals the rotor, skeletonized gear train, and solar-actuator mechanism.
  • Finishes include hand-polished bridges, blued screws, and Geneva stripes.
Key Benefits of the "Heliomechanical" Design
  1. Enhanced power reserve with solar-assisted recharge.
  2. Double escapement offers superior precision.
  3. Modular customizability for enthusiasts.
  4. Lightweight, skeletonized movement with modern aesthetics.
  5. Hemispherical balance wheel innovates on traditional watchmaking.
This design combines cutting-edge materials, improved energy efficiency, and visual artistry while staying true to the spirit of mechanical watches. Would you like me to focus on a specific part (like CAD concepts or technical schematics) or expand further on this design?
Now asking it to create a image of the dial..
Interesting.. although I can see this being more complex than this.. it seems a interesting idea.
Looking at those cogs, that would tell the right time twice a day. But with those hands, maybe four times...
And then having read the design brief it produced, you may as well just sandwich some bull's excrement between the case back and the crystal.
The point (yes it’a not functional) but the concept is not bad.
The way AI generation works is to simply blindly regulate a mix-mash of imagery it’s been trained on. It doesn’t understand the subject itself.
I thought it would be an interesting exercise.
Still enjoying my Zenith :)
But it has occasionally started to not trigger the chrono. It's done it a couple of times now anyway. So it may be making a trip to the manufacturer for a warranty repair :(
My speedy appears to do that 1 in 20 tries. It's almost imperceptible and I find myself looking for the fault. Given it's a chrono I wonder if it's just par the course that they get a bit 'sticky'?
Some speedy owners run the chrono as the second hand..might be an idea to give it a day running?
Stunning watch other than the spit-on-my-families-grave date window :D
