EKWB in trouble?
Yea you can, buy then can you actually take it to market? or does someone own patents for the methods you chose.
Everything's probably patented to death, I doubt it's as easy as you think.
Seems EKWB have 10+ patents, mostly for fittings though so probably not worth a whole lot to other manufactures, but they might be enough to block others
You can't patent cutting up a block of copper to make some grooves and fins and slapping a guide block on top of it with a couple of ports, that's just how blocks are made.
EK's patents look to be focussed on mounting (ExactMount used on the Velocity 2), fittings attachment (the screw shaft and fluid path on the ultra low profile Torque adapters), bridges and distribution (that weird triangular top plate for an Asus Formula board with VRM block paired with a Velocity block), and manufacturing techniques (aluminium-silicon-magnesium casting of cold plates).
Oh, and that tube bending block which looked interesting but sucks in real life.
So, if somebody wanted to embed spring-tensioned, non-rotating posts into their block's body and attach to the PCB via low-torque thumbscrews through a 2mm thick backplate on the rear of the motherboard, then yes they'll fall foul of one of EK's patents. Taking a 3mm endmill and a 0.1mm skiv to a block of copper isn't going to invoke the ire of anybody.
And these days going to market isn't nearly as difficult as it used to be. Plenty of turnkey solutions for storefronts out there to sell your wares, just be sure you have all the proper legal stuff in place and you can absorb the costs of RMAs.
Pumps though did they even have their own? I know those are patented? and those grooves and channels why can't they be patented? you could argue a cpu is just a few grooves and gates
slots have been patented before and I'm sure grooves have when they are arranged in a specific order for flow rate reasons or whatever
Yeah there's not much can't be patented
Asetek years ago went after swiftech
Simply because pump was mounted on the cpu block
Forcing swiftech to move their pump
Onto the radiator or reservoir which was also mounted
On the radiator
Other companies were and still are mounting pumps
On AIO blocks
Guess swiftech was a small player and didn't have the finances
To mount a legal defence though
If somebody managed to patent a specific channel, fin design and flow route that granted a significant performance advantage over the competition then good for them. That doesn't mean I can't make blocks any more, I just don't do what they did.
I think you're overreaching what can and cannot be patented when it comes to chopping up a block of copper.
How many times were references to small team,
Limited resources, etc mentioned
Well yeah because you didn't pay your employees is why
You now have a small team
Then got the ###### cheek to say we would like
To invite back some of the employees we ###### over
Created a new entity
Sounds like lawyer talk for put it in the wife's name
So we aren't liable sort of sneaky move
Four and a half minutes of use the right buzz words
About as sincere and believable as a kid
Caught with their hand in the cookie jar
Caught indeed, it's just more lip service and not saying much of anything. I'll continue to stay away, there is no drive to change.
Not that I particularly want to support them now, but does anyone know if they're releasing any 50 series blocks?
Alphacool have announced blocks for following cards
  • NVIDIA RTX 5080
    • Palit various models
    • Gainward various models
    • Inno3D various models
    • ASUS ROG Strix
    • ASUS TUF Gaming
    • MSI Suprim
    • MSI Gaming
  • NVIDIA RTX 5090:
    • ASUS ROG Strix
    • ASUS TUF Gaming
    • MSI Suprim
    • MSI Gaming
Do you have any news if EK going to release bolcks for 5080/5090s?
I seen the news about Alphacool as well. Do you guys know when are they going to be available?
Would you recommend any other vendor?
Yep EK posted on FB yesterday showing a block for a Astral 5090 and said others are on the way...
I've also been chatting with Derbauer on Overclock.net and he has said he is making blocks this gen and will be making one for the FE
https://i.~ibb.co~/9HpnFQS4/Screenshot-20250128-180050-Facebook.jpg
If they've gone properly bust I guess their creditors and accountancy consultants will be first in line to pick over the bones of whatever money (if any) is left over.
Customers with oustanding orders won't be first in line.
Think they've had some sort of buyout /buy in
Or merger
Or other tricky accounting practices
With it might be a Chinese company?
Though my memory isn't the best
So might not be Chinese
If there was administration involved, they may not honour the orders. Interestingly, they still seem to be manufacturing something and releasing products as the new FLT res range is showing stock being available from mid of last week. At least this gives us some hope for spares availability in year to come.. maybe ;)
Not in administration
Wasn't Chinese did say my memory wasn't great
Slovenian
Lm tek d.o.o
Probably find it's someone linked
In some way to ek
And just another example of sneaky accounting
Put assets in the wife's name
Or separate company that you actually control etc
