oil is supposed to stop it boiling over I thought - reduced surface tension ... but I wouldn't be putting olive oil in, any more (even though reducing pasta sticking maybe a myth)
Wasn't my post but I use that, Tastes completely different and miles better. Use it on everything.There was another thread about someone using pink Himalayan salt or something.
Absolutely ridiculous.
Yup olive oil is way too expensive these days, to be honest I switched over just to rapeseed vegetable oil years ago anyway.
get some MSG.
AHH the old cocaine of cooking.
Sorry dude, judging from the initial responses I felt like I had to dumb it down to that levelWas following until the Oliver video appeared![]()
Shouldn’t really be any danger of pasta sticking if you don’t drain it to an inch of its life like it’s the seventies, and make sure you get it in the sauce asap. (With starchy water!). I think the Italians are more amenable to adding butter or oil to the pasta once it’s cooked, if it’s not going straight in the sauce first some reason.oil is supposed to stop it boiling over I thought - reduced surface tension ... but I wouldn't be putting olive oil in, any more (even though reducing pasta sticking maybe a myth)
We have cheap olive oil for cooking and “nicer” stuff for dressings etc. Extra Virgin olive oil shouldn’t be cooked with really. We use groundnut oil for stir fries in the wok.Depends on the use. For example I do use regular vegetable for stir frying, but for some things I still stick with olive oil
Imagine using Oliver to make a point.![]()
You do indeed have to salt pasta water for those not in the know.
I don’t bother with table salt - we don’t buy it - just use sea salt. Food should be seasoned while cooking and once finished shouldn’t need it at the table!![]()
Imagine having to use Oliver to make a point for your audience!Imagine using Oliver to make a point.![]()
Ha that’s what I use but that’s the only salt we have. Got kilos and kilos of it up in the loft. We crush the rocks with a hammer and then grind it up to powder.There was another thread about someone using pink Himalayan salt or something.
Salt with sweet stuff is great. Salted caramel, chocolate etc. Open your mindPeople putting salt on a cookie should be shot
Absolutely. There is a small chocolate maker in Lincolnshire, (Duffys), does a "Salt N Nibs" chocolate bar. Thing of beauty.Salt with sweet stuff is great. Salted caramel, chocolate etc. Open your mind![]()
But it makes your pee softer?i pop a water softner salt tablet in, tastes a bit funny though, and gives me tummy ache
