- 15 Dec 2024
- Australia
and then I played with the BIOS again and wifi stopped working again in windows. had to reset cmos but at least I saved a bios profile. After resetting the BIOS back to default, wifi comes back again. I really don't want to play a process of illumination to work out which setting is the offender. this is dumb, a high end expensive board nerfed back to a normal board. I'm continuing asking MSI for a speedy resolution.
Edit: I spoke to MSI customer support and they couldn't advise when another BIOS would be released. They said they had never heard of this issue. I advised them many customers are having this issue and the advice I received from their engineer was to send the board back for a refund but they then explained it might happen on other boards using the same components and architecture. They said maybe go to intel, I cant obviously because I have a ryzen processor. I still have 2 weeks to send it back. Maybe another BIOS update will happen in the next couple of days, otherwise its going back.
