- 20 Jun 2023
- uk
I work for a plastics manufacturer. Mineral filler has been used for years. Standard talc of various grades, chalk/calcium carbonate and mica.I work for a sub-supplier to some automotive companies.
Where as before for instance a basic trim piece used to be pure ABS plastic, nowadays they often mandate 20% 'Talc' filler to bulk it out and to cut down on kg costs.
Would explain why plastics are going brittle faster with all the filler they add and doesn't bode well for things like inlet manifolds which used to be castings.
It makes the material meet customer specs but is also cheaper than plastic.
