Caporegime
- 18 Oct 2002
Remember lads it's Spurs AMD, no counting of chickens just yet
9070 (NOT the XT version)
Even original IGN article never said XT from what I saw.
AMD Radeon RX 9070 non-XT tested in COD BO6: 99 FPS on average at 4K Extreme settings without FSR - VideoCardz.com
AMD Radeon RX 9070 debuts in the world's first (unofficial) test IGN found the PC and they tested it. Radeon RX 9070 in COD:BO6, Source: IGN AMD hasvideocardz.com
Changing the naming schemes last gen is now confusing these new cards expected performance. You'd expect this gens second tier cards to be around last gen high end if they were going to do a high end this time around, but they're not. So going by that logic, 9070XT should be around 7900XTX.Maybe the speculation is all wrong?
7900 XTX - No direct replacement in the range, in line with the "no high end card" statement.
7900 XT - replaced by the 9070 XT as a 5070 Ti competitor.
7900 GRE/7800 XT - replaced by the 9070 as a 5070 competitor.
7700 XT - replaced by the 9060 XT as a 5060 Ti competitor.
7600 XT - replaced by the 9060 as a 5060 competitor.
The naming would make a lot sense if that were true TBF.
Shame the damn case logo is covering it up, can we use some Nvidia AI to remove it? lolWill say the screenshot doesn't give a great view of the card, but looks like its just 2 power connectors. So likely not a 3rd party xt as many of those seem to have 3
Shut up!No way this card is less than £600 if the performance is around a 4080/5070ti
The 5070ti is like £750,so I can't see them pricing it £200+ lower,but we'll seeShut up!![]()
its pretty nailed on they got wind of NVidias numbers and walked away to optimise more and save margins, but obviously thats my opinionI wonder if the reason AMD chickened out of announcing at CES was because they got rumours the much vaunted Nvidia Blackwell performance was all smoke and mirrors 4x fake frens nonsense.
So they are going to raise the prices of the RX 9070?
Real frames at real prices*
* the above post is pure sarcasm and not to be taken seriously.![]()
The way the £ against the $ is going right now I wouldnt be surprised.. £1 = $1.23 right nowThe 5070ti is like £750,so I can't see them pricing it £200+ lower,but we'll see
I imagine those AIB designs with 3x8pin and 300W+ TDP are gonna be clocked to the balls. If the stock boost is around 3GHz, we could see the OC versions with 3.3 or 3.4GHz. At those speeds it would be zero surprise if it could hit 7900XTX performance.In terms of transistors this could be as almost as much as Navi31! Maybe the performance is a better than we expected - it would explain the AIB partner designs!
CoD games are AMD optimised games, this has been known forever.
CoD is strong with AMD, so do remember that.
7800 XT is = to a 4070 Ti Super, you don't see that anywhere else... its one of very few games that are AMD optimised.
And as i have said, the interesting part is that the 7900xtx also gets high 90s in that bench mark. So pls ignore how the nvidia cards perform in black ops 6, it doesn't matter. If the 9070xt performs similarly to the 7900xtx in this game means it likely will in others.
Notebook check has tested BO6 on 7900XT and got same performance as IGN on the 9070 non XT
So 9070 = 7900XT
And 9070XT = ?
