- 24 Mar 2018
- Brighton
Salt is so old fashioned, now we have a spoon that makes your food taste like it has salt!
What exactly are you getting “right” here?There's a knack to getting it right
What exactly are you getting “right” here?![]()
You’re rinsing out all of the starch which will help emulsify your sauce. If you can’t time 8-10mins for your pasta with the rest of your cooking then I’m worried. Heck, you could just turn 99% of sauces off the heat before you start the pasta and they’d stay warm enough when tossed through with freshly cooked pasta.
I don’t doubt probably some restaurants do the above for means of having everything ready to go but there’s really no need for home cooking. Plus all the extra washing up and faff. Sod that!
So you're saving some of the starchy water?Nah, it doesn't rinse out all of the starch at all.
I've not had a jar of pasta sauce in the house for 15+ years. I don't see the need when at a push you could fry up some garlic, add a tin of tomatoes and simmer away for 20mins (on its most basic form) and get something perfectly good and way better than the sugary mess that is jarred sauces. If you prefer creamy sauces then we always have a pot of creme fraiche in the fridge which serves a very similar purpose.If you're cooking a jar of dolmio then maybe it's no so important![]()
I love how you're trying to be condescending and implying that anyone who doesn't do it your way is doing things badly or cheaply, while simultaneously being pretty clueless about how to cook pasta and pasta sauces well. Bravo.Nah, it doesn't rinse out all of the starch at all. If you're using cheap, thin spaghetti maybe, but a normal supermarket linguini for example is fine.
I'm a bit of a sauce nut. I have to get that right and 2 mins either way can be a big difference when using herbs. Those volatiles are, well, volatile... It's much easier to have the pasta ready to go as far as I'm concerned. If you're cooking a jar of dolmio then maybe it's no so important
And the extra washing up is the same colander/steamer I'd use to drain the pasta anyway. ie, there is none.
). I wouldn't ever criticise someone simply for being ignorant about food, but being ignorant and trying to act like you're an expert while trying to put down someone who clearly knows a lot more than you deserves calling out.I bought a big bag of MSG recently. Might try a bit of that in pasta..
Thoughts?
Edited to tone it down (a little). I wouldn't ever criticise someone simply for being ignorant about food, but being ignorant and trying to act like you're an expert while trying to put down someone who clearly knows a lot more than you deserves calling out.
Sorry, you're wrong. A really quick Google will help inform you on this subject; does rinsing pasta reduce starchThe only reason to do it another way is because you might rinse out the starch, which I don't. Nobody would ever tell the difference.
Yes, rinsing pasta after cooking significantly reduces the amount of starch on the noodles, as the water washes away the starchy film that naturally coats the pasta. This is why most chefs recommend against rinsing pasta unless you are specifically making a cold pasta salad where the starch could make the noodles clump together.
So why are you making it more difficult? In my house, we drain the pasta through the holes on the pan lid. So, draining into a colander and then rinsing, then boiling water and rinsing it again is absolutely laborious, uses more implements, more energy, more gas/electric, and time. There's just no need.it's cooking the pasta that's the most simple
I might decide I'd enjoy my dinner more if I went for a **** first.
Now I know the thought of eating a succulent meal does invoke some feelings of arousal, this is a well known fact in fact, especially if you are really in to your sauce making. But maybe wait until afterwards?![]()
Snort a line first then decide what to doI bought a big bag of MSG recently. Might try a bit of that in pasta..
Thoughts?
One of the least degenerate posts in this thread honestlySnort a line first then decide what to do
Yeah, I appreciate that some starch is lost when rinsing. However, like most things, this isn't a binary choice. If I used thin, cheap pasta and then boiled it until fully cooked, then rinsed it through whilst still hot, then I'd be rinsing more than noticeable amounts of starch. However, if I use thicker pasta, such as linguine for instance instead of a spaghetti, then boil it until it's not quite cooked, then flash cool it with cold water, (which as you'd know makes the starch less soluble AND may make it healthier https://www.healthline.com/nutrition/cooling-resistant-starch#:~:text=This process is called starch,and leads to health benefits.) THEN rinse it, I'm really not losing that much starch at all. I know that because like I said, I drain it in a steamer insert over the pan, so I get to see what drains. So you can tell me I'm wrong as much as you like but you're not right about my particular method. Much like you weren't about the extra washing up. Not everyone has pans with lids suitable for draining pasta from and invariably I'd have already used it as a colander whist prepping the sauce.Sorry, you're wrong. A really quick Google will help inform you on this subject; does rinsing pasta reduce starch
Again, not to be blunt but if you're such a "sauce nut" then you should realise how important the starch is to emulsify sauces with the pasta.
A chef once told me putting oil in the water means it makes the pasta slippery, and will stop sauces sticking well to it. Makes sense, but have never done a side-by-side comparison.I use Lo Salt and some olive oil, makes a big difference if you rinse the pasta when cooked
