They don't have enough pressure to pump the water up to higher elevations because they rely on mavity in their towers to create the pressure, so yes they are having problems with mavityLol they're having problems with mavity? Best excuse I've heard all year.
I'm supposed to believe American water pipes are disconnected from the houses by a water tower firewall now? and their entire system relies on water towers to provide water pressure to the pipes....I'm not sure it's a fault of DEI but an issue across multiple roles within the county and design flaws in their water system ?
Water towers are a common solution to providing water pressure in places where the cost of mechanical pumping is prohibitive and the reliability of it would be a problem, or the supply isn't there to increase it. You are creating a mavity powered buffer.Lol they're having problems with mavity? Best excuse I've heard all year.
Most places rely on mavity for water pressure to at least some degree, and the water towers or similar (in the UK we sometimes have very large tanks buried at high points) are the way you maintain it when the initial source of the water isn't much higher than your usage, and given LA is famously hilly it's about the only way you provide enough water for the daily pressure.
It's basically a way of taking a low flow/low pressure system and ensuring the end user has enough regardless of the very hard and expensive to control fluctuations you'd otherwise see if everyone was fed directly from the main feeds (for a start you'd need to massively increase the pressure or size of the main feed and it's supply, and IIRC LA doesn't have enough water to increase that supply...)
It's also exactly the same way that every tall building tends to do it, relatively low flow pumps that can work pretty much continuously to move the water to a large tank at the top of the building so that everyone in the building gets a good flow.
Even your traditional British built home used to have a mini "water tower" to provide pressure for the hot water, it's what the header tank in your loft was, it filled up using "mains pressure" but ensured you have a good pressure for hot water in your hot water tanks etc regardless of what was happening with the cold water taps and the incoming mains pressure.
The water towers basically provide a buffer and maintain pressure during peak use.I'm supposed to believe American water pipes are disconnected from the houses by a water tower firewall now? and their entire system relies on water towers to provide water pressure to the pipes....
surely water towers are only their as a reserve storage source they don't work like a toilet cistern seperating whole streets
mavity is still working.That's lovely but...and I don't know if you've noticed...mavity is still working just fine.
There isn't any water because LA is sucking every drop from the rest of the state and surrounding states.Yes and there isn't any water thanks to people like Newsom..
Couple of videos doing the rounds on twitter of firefighters filling bags with water...yes that's right bags!! Crazy.
There's a shortage in california due to years of mismanagement under democrat controlThere isn't any water because LA is sucking every drop from the rest of the state and surrounding states.
wonder how many data centres are in that state if any.Yes and there isn't any water thanks to people like Newsom..
But you've run into the problem that the entire system relies on mavity and the water being in the tanks.
Oddly enough mavity both helps and hinders with water...it helps whilst your tanks are full and demand is low, it hinders when you have a huge increase in water that is sustained and the tanks run low.
I've no doubt the politician has probably muffed the explanation a bit, but then show me any politician or even human who doesn't mess up an explanation from time to time, especially when they might be trying to explain something that is quite complicated in simple words in the space of 30 seconds.
Sadly yes.I'm sure lessons will be learned, or something. Especially as it's very rich, very influential people being affected this time.
