- 11 Sep 2020
- London
What, really? Which ones?Nvidia can check with AMD, they've got the experience as they've launched a couple generations in the past that had raster performance go backwards
I presume he means R2900XT vs 3870XT.What, really? Which ones?
I remember a few years ago KFA2 made a card (think it might have been a 3090) with a fan on the backplate, like the vanguard, and testing showed it didn't make an ounce of difference to cooling, so probably paying an extra £300 for a useless £10 fanI believe now it's Ventus, Gaming X but then it's tough between Suprim and Vanguard which will be top, I lean towards vanguard but yeah..
Mama mia, I thought we had it bad in the UK with VAT at 20%!25.5% VAT in Finland, too, i believe.
9m40s maybe gpu makers will reduce gpu die used for raster performance in exchange for more ray tracing
To be fair I believe it was the Asus Astranomical pricing edition where it was mentioned they changed the fin density to I assume have more effect from the backplate fanI remember a few years ago KFA2 made a card (think it might have been a 3090) with a fan on the backplate, like the vanguard, and testing showed it didn't make an ounce of difference to cooling, so probably paying an extra £300 for a useless £10 fan
Edit my mistake, it's the MSI 32G that has the backplate fans not the Vanguard
And if he is, he's also talking almost 2 decades ago. And even then the 2 cards traded blows, the 3870 was marginally faster overall and drew less power.
Both examples are different tiers/price-points, so not comparable in any way.5700xt vs Radeon 7 https://www.techpowerup.com/review/amd-radeon-rx-5700-xt/28.html
And now looks like 9070xt will possibly be slower than 7900xtx, so that could be another generation
Also I believe inno have made a few with an attachable 4th fan
If you're happy with what you have then that's all that mattersI'm happy that I got the 4080 Super 6 months ago, there's no way I was going to be able to get a 5000-series card especially at a decent price, but good luck to all who are in the market!
That looks awful
It does, but i'm genuinely curious how much it helps temps and affects noise levels. Hopefully GN review it.That looks awful![]()
