NVIDIA RTX 50 SERIES - Technical/General Discussion
I believe now it's Ventus, Gaming X but then it's tough between Suprim and Vanguard which will be top, I lean towards vanguard but yeah..
I remember a few years ago KFA2 made a card (think it might have been a 3090) with a fan on the backplate, like the vanguard, and testing showed it didn't make an ounce of difference to cooling, so probably paying an extra £300 for a useless £10 fan :cry:
Edit my mistake, it's the MSI 32G that has the backplate fans not the Vanguard
9m40s maybe gpu makers will reduce gpu die used for raster performance in exchange for more ray tracing
RT hardware has been available for about 7yrs since the 20 series came out, if anyone is still running 7+ year old PC hardware then it's way overdue for an upgrade by now. PC's have had it for 7 years, consoles though much slower have had the ability to run it for a few years and even top end phones can now do hardware accelerated RT, even the Steam Deck can even if it's very slow at it. There is no reason why anyone should be complaining that their hardware is incapable of even running some form of RT in 2025.
To be fair I believe it was the Asus Astranomical pricing edition where it was mentioned they changed the fin density to I assume have more effect from the backplate fan
Also I believe inno have made a few with an attachable 4th fan
Ahaha that's a 5 slot GPU
I bet what happened here is Gigabyte designed the card to work and look like last gen with the open vents at the back. Then when they saw Asus, MSI and others had built a 4th fan into their cards, they decided they had to as well but didn't have enough time To re-design and just stuck a 120mm case fan on the back with some screws lol
Wonder if someone will make a comically large heatsink at some point for fanless config?
It could keep it's own weight up be hitting the PC floor.
