I'll be keeping it around to use on the car too and it's been useful around the house so far, like you can see the radiator pipes inside of a fridge as heat signatures through the housing etc, useful to see if appliances are broken someways and stuff like that. Also useful for spotting peeping toms hiding in the bushes lolol.
It's useful for all sorts of things in the house - identifying damaged insulation on hvac/heatpumps, or leaking hvac pipes, leaking water from other pipes, air gaps where cold comes in around doors and windows, incorrect or missing spots of insulation in your ceiling or walls, it can tell if your roof is leaking, and it can even tell you if your shower or windows are leaking behind the walls etc and probably many more things I haven't thought about. Obviously it's great for electronics too, and yeah you will always win at hide and seek
