B550 version
If it's you first drive, then get one without a heatsink and use the motheboard plate because if you remove the heatsink from the drive you can invalidate the warranty.B550 version
So the crucial p3 plus is also a good drive?
Basically currently i have two drives installed:
1 x crucial p5 250gb
1 x samsung 980 1tb
I plan to take the 250gb and replace is with a 1/2tb drive and then remove some extra SSD drives
So i found a p3 plus 1tb for under £38
Bargain!
But it Can’t be true till it arrives from the port of shanghai though right lol
How much for 2TB?So i found a p3 plus 1tb for under £38
Bargain!
How much for 2TB?
Keep us updated if you go for it.
so here is a question...
my os is running on 1 x samsung 980 1tb
is there any advantage of me ghosting that drive on to the p3 1TB plus? ie will it be any quicker? or will there only be a very small difference in speed?
I doubt you would notice any differenceso here is a question...
