Man of Honour
- 20 Dec 2004
- Tamworth
Any recommendations for tyre shine?
GlossDo you prefer gloss or matte look?
Same as me, and I use Megs endurance as @Street suggested. To get a glossy finish, apply quite a heavy coat, leave it for 5 mins then lightly wipe with a dry microfibre. Then give it some time to dry fully before driving, otherwise it'll sling all over the wheel archesGloss
i was hoping IK did a 9L Battery operated sprayer, but they don't, only in a 12L which is too big for me really
any alternatives guys ?
what about one of these ?
i saw Fanntik sell one, but out of stock at present
Intrigued where this takes you. I assume you want it for your waterless washes?
ThanksI use the Meguiars Endurance High Gloss gel on mine. I don't bother with it over the winter, but over the summer it lasts a couple weeks before I redo it. The bottles are reasonably cheap and last me ages.
There's also the option of getting a 9L sprayer and just attaching one of those portable tyre inflators to it (if the sprayer has a pressure valve). Should be fine as long as the sprayer has a auto release value to release excess pressure.
I use the gtecniq wheel armour stuff, not cheap but does a really good job, might be a bit cold to apply at the moment though...What is the recommended Wheel protection, between cleaning? I had been using spray on cheap stuff on focus but it has ran out.
On the previous car I used poorboys wheel world (pink stuff, going from memory), I imagine it would be a pain to apply on the style of wheels on the mustang.
I have used autoglym extra gloss protection when in a pinch before, again not easiest to apply.
same one you use on the car bodyWhat is the recommended Wheel protection, between cleaning? I had been using spray on cheap stuff on focus but it has ran out.
