Tailwind!
On the subject of bike fit. Does anyone have one of those cleat position board thingies?
When i had my bike fit he used one to ensure things were aligned and it seemed a handy tool. Until i went and bought new shoes and cleats.... Been considering the Ali Express version rather than anything proper.
Smarter Shopping, Better Living! Aliexpress.com
es.aliexpress.com
Feels like my left one isn't quite aligned the same as my right foot, and whilst i'm not really noticing any issues, i'm also conscious that something might develop thats quick/cheap to fix.
Not tried one but have always considered getting one. But the few times I've had to measure up new shoes I seem to get it quite accurate... I hold the shoes up together, matching where the toes and ball of foot is for the cleat fore/back. Then use the rear of where my heel is for the angle. Every time I change a cleat I draw around the old one on the sole then screw the new one into the same place.
The guy for my fit did start from scratch, but also showed me. He puts tape on the innerside of the shoe. Got me to stand in them, jump up and down a few times and wiggle my feet around. Drew a mark on the tape then where the 'ball' of my foot is. Standing on the floor with feet in natural position on a line on the floor, 'draw' a line straight across the shoe to then mark the outer edge. Fit the cleat along that line (widest edge of cleat). Pedal wriggling feet, adjust angle of the cleat slightly so the fit is in the middle of the 'float' of the cleat in that natural position. Actually found I'm 'odd' but likely through riding - quite 'duck footed' when stood naturally (toes out, heels in), but put me on the bike my feet go fairly straight. Said he sees it a lot from people who've trained themselves to pedal straighter when they should have adjusted cleats more. But with no pain/injury didn't consider any need to change/correct it...
I'd say a decent bike fit is worth it, especially if you are going to invest in cycling as your hobby.
Oh definitely, but you probably don't 'need' one when starting out and if you've been fairly accurately sized by a shop to the right size frame and you're not borderline... If you pick up an injury, or just can't get something right. Or if you're towards the borders of standard sizes and stuff that's when a fit is really worth it's weight in gold (& can stop you buying the wrong frame size!)
I went to insoles quite early on from one of those shop fits. I've used the specialized 'bg blue' insole since then. Even before I became a Specialized fanboy. I tried some others and couldn't quite get as much comfort from them (but actually use them in a pair of workboots I have and my wellys). They're crazy money, but can buy them
new for ~£20 if you hunt around, sometimes see them pop up for £15 on ebay.
What Lakes did you get? My fitter recommended them, or Bonts to get a wider shoe. I bought a pair of EU42 standard width Bonts (Riot) and just can't get the fit right, like the uppers are not large enough so I feel cramped in them while they're really stiff so even fastened up loose they feel tight, yet the soles are perfect. I should probably have got a wide pair... I picked up a ebay used set of Lake CX176 in EU42 Wide and the fit is kinda-ok, but maybe need the non-wide. 'Roomy' feeling makes them comfortable but that is an issue, as the uppers are the opposite to the Bonts, lots of space, lots of flexibility and have to have the boas quite tight to feel 'fitted'. Feels like I bought exactly the wrong ones - should be wide in Bont and non in Lake. I have a standard fit EU42 Sidi shoes and they're like slippers. Super comfortable and stuff. Maybe they've grown with me. My daily shoe is a Specialized BG Sport, standard fit EU42 and although cheap shoes feel as comfortable as the wide Lakes with a little more stiffness in the upper. I've also had standard fit 2x Giro (good like the Spec), standard fit Shimano (too narrow and flexy soles) & standard fit Fizik (too narrow).
I'm not searching for the perfect shoe, but it feels almost like the harder I've tried the worse I've made the fit! Probably just flog these Bonts and get more fancy Specialized Torch for summer as they are quite often in deals.
@fez I don't know if any of that helps you choose shoes if you found the Torch too narrow!
Ordered myself a jazzy new summer helmet
Page not found
www.paulsmith.com
They look good, can't see where I saw it pop up (probably twotter) but a good price on them for a well regarded helmet. Quite hard to tell what the actual colours will look like in normal light - let us know!
Ah see, at first i wasn't sure if it was sarcasm and an odd thing that Paul Smith was getting involved in cycling
Paul Smith and Rapha have done stuff together for several years already, usually a great collab for some different colours than the standard Rapha block colour/pastel ones.
Rapha and Paul Smith's 1960's inspired collection + 2023 EF Pro Cycling team kits are now available to purchase from Rapha
road.cc
Discover the latest cycling collaboration from Paul Smith and Rapha and read our interview with real cyclists on how the sport has brought them together and what it has taught them.
www.paulsmith.com
